how fast will this be
Old Apr 20, 2003 | 11:35 AM
inutero11's Avatar
Default how fast will this be
i wanna get a integra ls and buy either a type r head or gsr head and put it on the ls block. will this be as fast as a gsr or alot slower? also,you guys think it will be worth it?
Old Apr 20, 2003 | 11:40 AM
neo1z's Avatar
Default Re: how fast will this be (inutero11)
LSVTEC, IMO, isnt the best thing you could do with your time. With an LS motor...Id just go ahead and turbo it. Ive seen very few LSVTECS that didnt have problems down the road.
However, a successful LSVTEC will hang with a GSR quite well. Probably faster.
Old Apr 20, 2003 | 01:40 PM
BerlinaAP2's Avatar
Default Re: how fast will this be (neo1z)
slow
Old Apr 20, 2003 | 01:49 PM
MooreBoost's Avatar
Default Re: how fast will this be (ApexiSi)
Just get the LS and turbo it, or just buy a GSR. There is no point in buying the cheaper of the two, spending aton on it just so that it will hang with a GSR, where as an LS would beat alot of cars.
gmoore
Old Apr 20, 2003 | 01:52 PM
inutero11's Avatar
what kind of problems
Old Apr 20, 2003 | 02:24 PM
DOHC_VTEC's Avatar
i say go LS turbo.
or if u just want a quick daily driven car go for a GSR
Old Apr 20, 2003 | 02:29 PM
MooreBoost's Avatar
Default Re: how fast will this be (DOHC_VTEC)
Any time you seriously alter a car you will have problems one way or another. They may not be big, but problems none the less. Im not sure of the specifics, but Im sure you may have some electronic issues. Not to mention the hassle of getting it all done in the first place. Just stick with a GSR or LS-T.
gmoore
Old Apr 20, 2003 | 02:36 PM
.RJ's Avatar
.RJ
you'll spend alot less money just buying a GSR instead of buying a LS and installing a GSR head on it.
Old Apr 20, 2003 | 02:46 PM
CNSK's Avatar
Default Re: how fast will this be (.RJ)
my buddy had a LS/VTEC in a eg, and best time was a 14.8 and had 3 different drivers driving it. only once did it hit 14.8 donsistan low 15's. His LS swap alone had ran a 14.6 best e.t. He sold it his car to some guy and now driving a s2000 . If i was you just go LS with some sort of force induction.
Old Apr 20, 2003 | 02:57 PM
Weston's Avatar
LS/VTEC is a can of worms no matter how you go about it. Turbo is a can of worms, but a lot of $$$ can fix it. My choice would be a JRSC with quite a bit of cooling. It makes more usable power (ie good torque @ almost all rpms), isn't half-assed, and there aren't very many worms in that can.
Old Apr 20, 2003 | 05:29 PM
P1mpSlap's Avatar
B00St!
Old Apr 20, 2003 | 05:48 PM
rota426's Avatar
Default Re: (P1mpSlap)
buy a b20, and mate it with a b16 head. without turbo, if you do everything right, you'll be passing gsr's, at least from the start. turbo it and you'll be passing much more.
hybrid
nate
playalistic2
Jan 18, 2006 07:29 PM
95SniperSi
Dec 8, 2003 05:09 AM
HmgLauj69
Dec 18, 2002 12:04 PM
HondaDriver85
May 16, 2002 04:33 AM
Thrillhouse
Apr 29, 2002 12:47 PM
