Need help, cant put it in first sometimes
Old Apr 21, 2003 | 08:55 AM
VintegraGSR96
Guest
Posts: n/a
Default Need help, cant put it in first sometimes
Sometimes on the light it wont go in to first, so i have to start from second and them it goes in first very easily! Same thing happends with reverse!
Old Apr 21, 2003 | 10:44 AM
NY-Trizz's Avatar
Your syncro's might be shot. get a tranny shop to check it out, or if you feel confident enough, pull the tranny out your self and check the teeth on the splines of the syncro's
Old Apr 21, 2003 | 10:48 AM
UnionCity LS's Avatar
Default Re: Need help, cant put it in first sometimes (VintegraGSR96)
ummm..before i put my car in first sometimes i put it in reverse then first..and before reverse..ill put it in first...kinda to line them up....i dont know but yeah...thats what i do...
Old Apr 21, 2003 | 11:02 AM
Rory Breaker's Avatar
Totally normal. First and reverse are a bit sticky on Integras. I usually just pop it back in neutral, let up the clutch, depress it again and try again and it works fine.
Old Apr 21, 2003 | 11:33 AM
LSvtec03's Avatar
when my 1st is sticky i just let of the clutch and press it down again and it goes in fine
Old Apr 21, 2003 | 11:46 AM
tilt's Avatar
Happens on occaision for me too. And yeah, either roll the car just a tad and it will slide in or let off the clutch and redo it.
champwhiteEG6
Sep 19, 2007 08:54 PM
ep3 type-s
Aug 1, 2007 06:05 PM
civicdohc
Jan 13, 2004 09:15 PM
AndyD
Sep 24, 2002 03:16 PM
