help with removing lower dash
Old Apr 19, 2003 | 01:18 PM
slowacura's Avatar
Default help with removing lower dash
anyone have any pics or instructions on removing the under dash kick panels and center console area - i want to do it right and not snap and break any parts off. thanks
Old Apr 19, 2003 | 04:19 PM
Danger's Avatar
Default Re: help with removing lower dash (inteGSR)
what year integra do you have ? 94-01 is pretty easy to take apart
Old Apr 19, 2003 | 07:23 PM
slowacura's Avatar
Default Re: help with removing lower dash (JonnyDanger)
yes i have a 94
Old Apr 19, 2003 | 08:44 PM
Danger's Avatar
steps to removing the center console.....
1-remove the little plastic piece from underneath your e-brake handle , remove those 2 bolts .
2-on the sides of the armrest piece there are 2 screws , one on each side , remove those . now the arm rest piece should come out .
3-on to the piece that connects to the dash . the front of this piece has 2 screws , one on each side , take those out .
4-now remove your ash tray . look inside there and there should be 3 screws back there , take them out . now that hole ashtray/lighter section should be able to come out.
5-now that the ashtray section is removed you will see 2 screws towards the top where you just removed that last piece , take those out .
that should be all the screws you need to take out to remove the center console
85_305
Honda Civic (2001 - 2005)
Aug 26, 2009 09:44 AM
Junkyard2000
Nov 8, 2005 11:50 AM
masteroflife67
Sep 29, 2005 03:27 PM
idsignature
Aug 19, 2005 04:55 PM
logic
Oct 12, 2003 03:31 PM
