98+ conversion
Old Apr 21, 2003 | 10:53 PM
Gs-RAW's Avatar
Default 98+ conversion
What is involved with doing this conversion? Just worried about changing the bumpers and lights. Front headlights, corner lights, bumper cover, and rear bumper cover, and all red lights....
Am I missing anything?
Anyone who has done this do the headlights just fit, and the bumpers bolt up? Did you need to modify anything, how easy is it to do.
My buddy just bought a kit and will sell the bumpers to me pretty cheap so...
thanks!
Old Apr 22, 2003 | 02:13 AM
tC_Dragon's Avatar
Default Re: 98+ conversion (Gs-RAW)
well everything is bolt on.. and its not complicated at all... if you go to bseries.net they have a guide on removing ur bumper... and team-integra.net might have one as well.... and then u jus unbolt the headlamp assemblies... and thats it... the corner lens are hook up to ur bumper so they will jus come off.. jus make sure to pull all the bulbs out of all the light assemblies.
All you need:
1) Bumper
2) Headlamps assemblies(1 for each side)
3) Corner Lens(One for each side)
To recap,
Yes it will bolt up.
No its does not require any specialty tools
Yes there is no custom modifications required to make this work
EDIT: Sorrie didn't see the part about hte rear...
yea the taillights are a direct replacement.. jus remove the interior panels in the trunk and you will see the nuts that hold the taillamps in place.. jus remove those adn the bulbs and it will come out... jus make sure not to drop the nuts... people do that ALL the time.
THe rear bumper cover is a direct replacement as well. Jus unbolt old one, bolt on new one.
Old Apr 22, 2003 | 08:23 AM
SIK IN DA HED's Avatar
New User
Default Re: 98+ conversion (pdcdragon)
headlights, bumper, and corner lamps. thats it.
Old Apr 22, 2003 | 11:19 AM
Boost Ambassador's Avatar
yep, headlights, tailights, bumpers, and corners! Good luck it's worth it!
Old Apr 22, 2003 | 12:08 PM
arsenaldragster's Avatar
Default Re: (LS60-1)
direct bolt ons.. show us a pic.. just make sure you paint the stuff to match (if it isnt already)
Default Re: (arsenaldragster)
p.s. my avatar was my 95 with a 99 front and rear bumpers, taillights!
Old Apr 23, 2003 | 11:14 PM
LS511's Avatar
Default Re: 98+ conversion (SIK IN DA HED)
Whoa wait. I just converted my 94 to the 98 bumper and there's something you need know. There are two brackets used to keep the corner lights stable. Without the brackets, the corner lights can't stay in place. I suggest you buy new brackets to fit the cornerlights. What I did was I ghettoized it. I bent the brackets to make it fit into certain holes on the bumper. However, it's extremely hard to bend having it being metal. I didn't want to wait because these parts are rare in the dealership so that's why I fixed it myself. If you can't wait ghettoize it.
I Like Hondas
Nov 1, 2006 10:53 AM
ninety-five_DB
Nov 15, 2005 11:50 PM
aira
Apr 7, 2003 06:44 AM
FrostyDC4
Feb 25, 2003 10:47 PM
acuraLSSE95
Nov 26, 2001 07:51 PM
