Sparkplug wire order on cap?
Old Oct 28, 2004 | 02:36 PM
Chewie's Avatar
Default Sparkplug wire order on cap?
Putting on new spark plug wires. Wasn't paying attention to the order of wires on cap? anyone have a illustration?
It is for a 99 GSR
Old Oct 28, 2004 | 02:41 PM
LSvtec03's Avatar
Default Re: Sparkplug wire order on cap? (Chewie)
i think its
3 4
1 2
looking at the dizzy from the passenger side
Old Oct 28, 2004 | 02:43 PM
Chewie's Avatar
Default Re: Sparkplug wire order on cap? (LSvtec03)
yes it is , found it on team-integra.net. Thanks for your quick reply
Old Oct 28, 2004 | 04:20 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
3 4
1 2
Close but upsidedown.
1 2
3 4
Old Oct 28, 2004 | 05:55 PM
LSvtec03's Avatar
Default Re: Sparkplug wire order on cap? (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">
1 2
3 4 </TD></TR></TABLE>
wrong, budday, ive got my helms right here. it's definitely...
3 4
1 2
also, if you were right, then that would mean your engine rotates clockwise
Old Nov 1, 2004 | 04:40 AM
Hype-R Stalker
Ok, that first one was wrong, i had it backwards.
Looking at it from the front it's... (I checked in my car and this is what it had)
2 1
4 3 (Distributor)
1 2 3 4 (valve cover)
What kind of angle would you be looking at it to have this one?
3 4
1 2
Haha, I know it's an old post but the order was bugging me.
Old Nov 1, 2004 | 05:24 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote"> 2 1
4 3 (Distributor)
</TD></TR></TABLE>Ummm.... Cylinder numbering always starts from the front of the engine. #1 is at the timing-belt end, #4 is closest to the flywheel.
Old Nov 1, 2004 | 07:46 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What kind of angle would you be looking at it to have this one?
3 4
1 2</TD></TR></TABLE>
From the passenger-side fender.
The distributor rotor always points to the bottom-left when the motor is at TDC #1 compression stroke (when the spark plug fires) and then it transitions into the power stroke.
Old Nov 1, 2004 | 08:22 AM
silvervlll's Avatar
the order is 1 3 4 2 starting at the bottom left and rotating in a clock wise rotation. If you are looking from the passenger side.
Old Nov 1, 2004 | 09:09 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">Ok, that first one was wrong, i had it backwards.
2 1
4 3 (Distributor)
3 4
1 2
Haha, I know it's an old post but the order was bugging me.</TD></TR></TABLE>
because on the valve cover, the cylinders are numbered 4 3 2 1. cyl 1 is at the front, closest to the valve cover. your order is right, you just had the cylinders numbered backwards.
OziD
Dec 4, 2007 03:48 PM
Ep1dem1c
Jul 3, 2007 10:51 AM
mortificationrock
10
May 22, 2007 07:51 AM
mike93boost
Feb 23, 2006 07:11 PM
Mr. JDM-GSR
10
Dec 30, 2004 10:10 PM
