solid cel good ecu
Old Oct 28, 2004 | 02:05 PM
benjamin's Avatar
Default solid cel good ecu
hey guys I am geting a solid cel when i jump for codes, but i put my ecu into my friends car and it worked. My car is a 94 LS and the engine is 96 b18c-r i am using a conversion harness and the obd2 p73 ecu.
could the harness be wired wrong or is there something else that would cause a solid cel, other than bad ecu.
tia
Old Oct 28, 2004 | 04:25 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: solid cel good ecu (benjamin)
You need to check the code that the CEL is sending. Do a search on how to check for the CEL codes and come back with code number and we can help you better.
Doh, my bad! It didn't click that he had used the jumper!
Modified by Gee3 at 10:36 PM 10/29/2004
Old Oct 28, 2004 | 05:32 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: solid cel good ecu (Gee3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 &raquo;</TD></TR><TR><TD CLASS="quote">You need to check the code that the CEL is sending. Do a search on how to check for the CEL codes and come back with code number and we can help you better. </TD></TR></TABLE>
I think he knows how to do that. He is saying that the ECU puts out a solid CEL (doesn't blink) as soon as it's plugged in (regardless if you've jumped the ECU plug or not).
In my experience, that happens when there is a bad ground somewhere, or no ground at all. Make sure all your grounds are there. There are 5, right? Alternator, transmission, valve cover, battery, and thermostat area.
Also make sure you have the correct harness.....sometimes they will fit, but if it's not the correct one, or it doesn't fit "correctly" it will do that as well.
Old Oct 29, 2004 | 04:02 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benjamin &raquo;</TD></TR><TR><TD CLASS="quote"> hey guys I am geting a solid cel when i jump for codes...</TD></TR></TABLE>That means there are no codes stored. If your engine doesn't start, look for other reasons. Like a harness that's wired up wrong or maybe something isn't getting power.
Got fuel? Got spark?
Old Oct 29, 2004 | 04:22 PM
benjamin's Avatar
Default Re: solid cel good ecu (JimBlake)
i printed off all the pinouts for obd1 and obd2 so i am going to check my ecu conversion harness, and check all my grounds because that is a good possibilty, electronics are not my strong suit.
thanks for the help
Old Oct 29, 2004 | 09:31 PM
benjamin's Avatar
i checked the grounds and all the wires i had to lengthen and it was all good, so i checked the plugs that seemed to plug right up and noticed some of the wires from the car side obd1 plugs had wires that led to nowhere, i am assuming this is not good, i am going to put the LS harness on my engine so all the plugs line up.
my question is for the dizzy, injectors, and alt can i just rewire those to obd1 and if so does any one know how.
tia
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
radicaled434
Feb 23, 2013 06:45 PM
1sikhatch
Jan 31, 2010 09:06 AM
gtcaraudio
Jan 25, 2008 06:57 PM
B18EG6
Nov 8, 2002 07:22 AM
