B18/B16
Old Oct 27, 2004 | 06:59 AM
HONDA RR's Avatar
Default B18/B16
DOES ANYONE OUT THERE HAVE A B18C GSR HEAD WITH A B16 BLOCK? If you do. What does it run like? How reliable is it? ; is it a direct bolt on where your don't have to modify either the head or block.
Old Oct 27, 2004 | 07:21 AM
BDBGoalie1982's Avatar
Default Re: B18/B16 (MITSUBA)
Why? if anything, do a B18 Block and a B16 head
Old Oct 28, 2004 | 02:35 AM
HONDA RR's Avatar
Default Re: B18/B16 (BDBGoalie1982)
its easier to get hold of a b16 block, all b16 blocks are arleady designed for a vtec setup. if i were to use a b18 ls block i would have to do a lot of work in setting up the oil lines. i want something where i can just bolt on and go.
Old Oct 28, 2004 | 04:42 AM
Deep's Avatar
I've heard about that build and thought it was a joke at first but from what I here it runs pretty decent but to most it just doesnt make much sense. I should be a direct bolt on.
Old Oct 28, 2004 | 04:47 AM
lanojp1's Avatar
if you rebuild the block then it shouldnt matter what block you go with...
von_clutch
Apr 28, 2007 11:05 PM
Jxi8s2k
Dec 21, 2005 08:52 AM
xmd
11
Dec 17, 2003 04:10 AM
b00stn
Oct 20, 2002 06:58 PM
