b18C1 Setup
Old Oct 26, 2004 | 03:55 PM
95BlkGSR's Avatar
Default b18C1 Setup
what compression pistons should i go with guys... will be all motor for now...want NOS, but also someday maybe turbo... mods listed below
Old Oct 26, 2004 | 04:01 PM
lanojp1's Avatar
Default Re: b18C1 Setup (95BlkGSR)
uhh...like 10.5:1 or so...its up to you basically..
Old Oct 26, 2004 | 04:13 PM
95BlkGSR's Avatar
Default Re: b18C1 Setup (lanojp1)
i no its up to me, but i dont know enough about compression to make a decsion that i feel it right...yea i can chose w/e but i want something that is gonna benefit me not hurt me
Old Oct 26, 2004 | 04:58 PM
b16sedan's Avatar
If you're going to go turbo later don't buy pistons now.
Old Oct 26, 2004 | 05:16 PM
92SleepyHB's Avatar
Default Re: b18C1 Setup (b16coupe)
I would decided now whether N/A or boost.....I'm running 10:5:1 compression on JE Pistons. "Picture me rollin' in my 500 Benz."
Old Oct 26, 2004 | 05:31 PM
95BlkGSR's Avatar
Default Re: b18C1 Setup (92SleepyHB)
if i got Turbo what compression--
if i stay All motor what compression--
Old Oct 26, 2004 | 05:36 PM
b16sedan's Avatar
9:1
12:1
Old Oct 26, 2004 | 06:04 PM
lanojp1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">9:1
12:1</TD></TR></TABLE>
in a nutshell, there ya go
Old Oct 26, 2004 | 06:11 PM
95BlkGSR's Avatar
12:1</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">
in a nutshell, there ya go </TD></TR></TABLE>
So if i was undecided i should go like 9.8:1, which could work with both?
Old Oct 26, 2004 | 06:20 PM
johnmay19's Avatar
You really need to pick which route you want to go. N/A you need higher compression. So with 9.8-1 you would still be down some power.
Old Oct 26, 2004 | 06:23 PM
95BlkGSR's Avatar
Default Re: b18C1 Setup (johnmay19)
yea, i think it looks best to build up around everything else, then get pistons later, just because im undecided...i just figured since my car has 107,000 miles pistons would help alot..
ill jus build other things first....
...thanks guys
Old Oct 26, 2004 | 06:26 PM
lanojp1's Avatar
i would really STRONGLY recommend doing all internal work at the same time..seriously..its gunna save you serious money and time..
Old Oct 26, 2004 | 06:29 PM
johnmay19's Avatar
Default Re: (lanojp1)
Not if he wants to go a different route later. Then have to change the pistons again.
Old Oct 26, 2004 | 08:15 PM
Dung's Avatar
If you are planning to do that then I think the best is to use the same pistons and just buy new rings for it
jdmredgsr
Mar 31, 2007 04:38 AM
Dmc1
15
Feb 6, 2006 11:06 PM
turboblkek
Jun 7, 2005 10:20 AM
95BlkGSR
Oct 26, 2004 06:20 PM
Maxboost00
Oct 1, 2004 10:42 PM
