Quick question about ECU's
I've got a '91 Integra, I'm putting a B16A in it (cable trans), I have an ECU that is for the B16, but it is for an automatic transmission, will it at least operate the engine semi-decently with a manual transmission installed?
Thanks,
zeleftikam
Thanks,
zeleftikam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeleftikam »</TD></TR><TR><TD CLASS="quote">I have an ECU that is for the B16, but it is for an automatic </TD></TR></TABLE>
all bseries vtec engines came w/ manual transmission....i don't follow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawdad689 »</TD></TR><TR><TD CLASS="quote">
maybe it's not a usdm ecu...follow?
</TD></TR></TABLE>maybe it's not a usdm ecu...follow?
It will run, but it will idle high like someone said. Plus you will throw a code or two depending on the work done. On mine, (after a 5-speed conversion), I threw a 1660 code for the automatic shift solenoid.
I assume this is not a USDM ECU?
