Help me.
Old Nov 22, 2004 | 09:22 AM
Turboredteg's Avatar
Default Help me.
Ok so I'm driving today and I'm on the way to get my tranny swap when my 94 teg dies out the roads are wet but i checked what I could and its all pretty much dry. So I try to start it and it just cranks over. could a fues be blown or is it the coil pack. thanks
Old Nov 22, 2004 | 09:56 AM
Geno's Avatar
Default Re: Help me. (Turboredteg)
My teg did this about a year ago and it turned out to be the ignition coil. I would start with your electrical system if you know everything else in the car was workin fine.
Old Nov 22, 2004 | 10:04 AM
rgaray's Avatar
How many miles on the odometer. Could also be your timing belt.
Old Nov 22, 2004 | 10:18 AM
burnout289's Avatar
Default Re: (rgaray)
sounds familiar. i had to replace ignitor and coil. about $60 each or so. did you check for spark? good luck!
p.s. PLEASE make your titles more descriptive. it helps out people down the road who want to search.
Old Nov 23, 2004 | 01:51 PM
Well I just figured it out. It jumped Timing. so I guess my car will be down for the night. and i hope that I didn't bend any valves. ehh oh well
Old Nov 23, 2004 | 02:12 PM
EKB18BPR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray &raquo;</TD></TR><TR><TD CLASS="quote">How many miles on the odometer. Could also be your timing belt.</TD></TR></TABLE>
ummm....no. he would be able to see if the timing belt had broken. its something not obvious or else he wouldnt be asking. im pretty sure he opened the hood and checked everything possible before asking us.
so what kinda car is it and what happened just prior to car dying?
Old Nov 23, 2004 | 03:17 PM
greaseball's Avatar
Default Re: (98B00STED)
[QUOTE=98B00STED]
ummm....no. he would be able to see if the timing belt had broken. its something not obvious or else he wouldnt be asking. im pretty sure he opened the hood and checked everything possible before asking us. QUOTE]
ummm...no. visual inspection couldn't tell you if you broke a timing belt. you need to remove the crank pulley and plastic cover over the oil pump(among other things...a/c...p/s) to get a good look at the tensioner. what if he broke the belt down by the crank?
Old Nov 23, 2004 | 03:56 PM
EKB18BPR3's Avatar
Default Re: (greaseball)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greaseball &raquo;</TD></TR><TR><TD CLASS="quote">
what if he broke the belt down by the crank? </TD></TR></TABLE>
HAHAHAHA it doesnt matter where the timing belt broke, if it broke while driving, its shreaded and you would know. i know cuz my stock motor broke a timing belt and bent my vavles. that lead me to build my turbo b18b. trust me, if u broke ur timing belt, u would know.
Old Nov 24, 2004 | 06:12 AM
greaseball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">
HAHAHAHA it doesnt matter where the timing belt broke, if it broke while driving, its shreaded and you would know. i know cuz my stock motor broke a timing belt and bent my vavles. that lead me to build my turbo b18b. trust me, if u broke ur timing belt, u would know. </TD></TR></TABLE>
hey dipshit, timing belts don't always shred/break. i've seen a lot of them that had a patch where the teeth were stripped off. if that happened on your motor i guarantee you would not be able to tell with any kind of visual inspection, unless of course...YOU HAVE X-RAY VISION! HAHAHAHA
Old Nov 24, 2004 | 11:16 AM
Well lost a couple of teeth on the belt and I bent a freakin valve, so what should I do? should I go built and p&p ls head or go ls/vtec any suggestions? has to be low comp though cause the turbo.
Old Nov 24, 2004 | 12:14 PM
Geno's Avatar
Default Re: (Turboredteg)
If your going turbo just get another ls head, they are cheap and the money saved could be used for more go fast parts.
Old Nov 24, 2004 | 01:29 PM
EKB18BPR3's Avatar
hey dipshit, timing belts don't always shred/break. i've seen a lot of them that had a patch where the teeth were stripped off. if that happened on your motor i guarantee you would not be able to tell with any kind of visual inspection, unless of course...YOU HAVE X-RAY VISION! HAHAHAHA </TD></TR></TABLE>
why do u have to start calling names? anyway the honda timing belts will never strip their teeth.
and for the guy who posted this thread...ur valves arent bent. i gurantee it because LS b18b1 motors are made so valves and pistons dont touch, even if ur if set ur timing 90, 180, 270 degrees off. and even if u do have couple of stripped teeth (which i highly doubt), that wouldnt cause ur car to die. anyway how do u know u got bent valves? did u take the head off?
Old Nov 25, 2004 | 12:19 PM
I know I have some bent valves cause when we started the car It had a horrible miss so we took off the head and there I was with two bent in the first hole.so I am getting a b20 pretty cheap and I got a hold of a vtec set up so I'm going to see how it goes.
Old Nov 29, 2004 | 07:15 AM
greaseball's Avatar
anyway the honda timing belts will never strip their teeth.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboredteg &raquo;</TD></TR><TR><TD CLASS="quote">Well lost a couple of teeth on the belt and I bent a freakin valve, so what should I do? </TD></TR></TABLE>
and for the guy who posted this thread...ur valves arent bent. i gurantee it because LS b18b1 motors are made so valves and pistons dont touch, even if ur if set ur timing 90, 180, 270 degrees off.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboredteg &raquo;</TD></TR><TR><TD CLASS="quote">I know I have some bent valves cause when we started the car It had a horrible miss so we took off the head and there I was with two bent in the first hole.
well 98boosted looks like you're full of misinformation. oh, and i wasn't name calling, i know a dipshit when i hear one!
Old Nov 29, 2004 | 09:08 PM
Well never say never cause it did strip the teeth I'll try to post some pics and yeah you can bend a valve or maybe I'm just one in a millon i duno thanks for the info tho. oh yeah I'm going b20 it outa be nice on 10 pounds. hey on a hole nother subject how much can I safely boost on 110 octane on a b20?
clewis3
Mar 23, 2010 11:49 PM
slikz714
Apr 27, 2009 03:18 AM
gq420j
Jun 12, 2008 10:55 PM
Buffs8080
Jun 7, 2005 10:42 AM
G a b e
Dec 14, 2002 09:29 PM
