PR4 ecu?
Old Nov 19, 2004 | 01:16 PM
kyden's Avatar
Default PR4 ecu?
would a pr4 ecu work for a 99 b18b? i have the conversion harness and i need an ecu for my swap this weekend.. the only ones locally i can find are pr4's..
Old Nov 19, 2004 | 01:26 PM
MolecularIntegra's Avatar
Default Re: PR4 ecu? (kyden)
Yes it will work. It's an OBD-0 ecu. So you have to run everything ODB-0. Or Run everything OBD-1 on the engine and use a conversion harness on the ECU to convert its plugs from OBD-0 to OBD-1
Old Nov 19, 2004 | 07:58 PM
kyden's Avatar
Default Re: PR4 ecu? (MolecularIntegra)
i thought the 92-93 integras were obd1?
Old Nov 19, 2004 | 08:00 PM
thaiphob's Avatar
Nikon!!!
yes the 92-93 tegs were obd1 the pr4 you have should be the same. if you have the conversion harness your golden!
Old Nov 19, 2004 | 08:03 PM
kyden's Avatar
Default Re: PR4 ecu? (thaiphob)
i have the obd2b-1 conversion harness.. so that should plug right in correct?
Old Nov 19, 2004 | 08:30 PM
mr.beeks's Avatar
I cant believe that is the only ones you could find.
what car are you using it for
Old Nov 19, 2004 | 08:42 PM
Default Re: PR4 ecu? (mr.beeks)
There are OBD-0 and OBD-1 PR4 ECUs.
Old Nov 19, 2004 | 10:45 PM
RaNMaN's Avatar
Yes it will work fine. I am using a modded and chipped PR4 in my '98 turbo RS and it works fine. And mine works with a OBD2 to OBD1 converter. The computer fuel programs were the same online that we found, and i was able to add boost to mine. I hope that it works for you too. Good luck.
rich7777
Sep 19, 2009 09:19 AM
stevil_knevil
Feb 10, 2009 01:39 PM
HybridKOOP
Jun 19, 2006 12:29 PM
