Checked Compression Today
Old Nov 21, 2004 | 09:12 PM
BDBGoalie1982's Avatar
Default Checked Compression Today
Well, my motor is spitting out a black liquid on my car so i figured it might be oil, so check the compression and other simple tests. I hook up my tester and take the reading off 1: 300(or higher, the needle stopped), same thing on all the rest of them, 300psi or higher all the way across.
So anyone know of where i can get a 400-500psi max guage? Can i just use any gauge, and hook up the quick disconnect to it?
If compression is good, possibly rings? Leakdown test?
I also run a oil cooler, so i could have something to do with that. Could also possible be the PCV too.
Any advice will be appreciated
Old Nov 23, 2004 | 06:43 AM
Default Re: Checked Compression Today (BDBGoalie1982)
I alos forgot to add,
B18C Block - Fully balanced, ARP rod bolts, CTR Pistons
B16A Head - Full ITR internals, valvetrain and cams, milled .0035
Any chance the piston rings blow off due to high compression?
jdmek2277
17
Feb 2, 2009 08:12 PM
turbociv910
Sep 9, 2008 05:26 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
311
Dec 14, 2002 12:18 PM
ShootingStar
Aug 31, 2002 05:59 PM
