vtec not working??
Old Nov 22, 2004 | 07:23 PM
veilsides2000's Avatar
Default vtec not working??
What are some reasons that the vtec might not work. i tried searching and it came up that if your vss isnt plugged in then it wont engage. My question is that can there be anything else that can cause this problem?? any help would be greatly appreciated thanks
Old Nov 22, 2004 | 07:45 PM
posjr's Avatar
Default Re: vtec not working?? (veilsides2000)
Any codes? Also are you sure it's not working. Is your motor cutting of and high end?
Old Nov 22, 2004 | 08:06 PM
stasi's Avatar
Default Re: vtec not working?? (posjr)
An issue with the solenoid.
Old Nov 22, 2004 | 08:21 PM
LSvtec03's Avatar
Default Re: vtec not working?? (stasi)
check your oil level.
Old Nov 23, 2004 | 11:19 AM
JDM_Spec's Avatar
Default Re: vtec not working?? (LSvtec03)
probably you dont have vtec, LOL, check the oil line for vtec, it might be blocked
Old Nov 23, 2004 | 12:14 PM
JustinG60's Avatar
Default Re: vtec not working?? (JDM_Spec)
certain check engine cids causes the VTEC to not kick in... there is a good thread on the top of this to tell you how to check for codes and what they mean you should check it out...
Old Nov 23, 2004 | 02:31 PM
flow_azn's Avatar
I ran into problems like that too. it all started after i swaped heads because my valve seats were all messed up. after we swapped the head and i tested it outthe check engine light would go on and i checked the code and it was the vtec solenoid so i unplugged it and put it back on then i reset my ecu. after reseting my ecu and what not the engine light turned off. then id start to drive it hit vtec every once in a while couldnt really feel vtec very well then the check light would turn back on. do you think my vtec solenoid is bad? im thinking the oil pressure has to do with some of it. or do you think my lines are clogged? any suggestions would be appriciated thanks
Old Nov 23, 2004 | 04:50 PM
T S R Performance's Avatar
Default Re: vtec not working?? (flow_azn)
Take the solenoid off the motor (3 10mm bolts) and make sure the screen isnt clogged. ANd also check your oil level
Old Nov 25, 2004 | 12:36 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: vtec not working?? (T S R Performance)
Yea check the Oil. But i had a problem with my Speedo where it wasnt reading any MPH and Vtec wouldnt Engage because it thought the car wasnt moving. i Dunno really weird
Old Nov 27, 2004 | 10:25 PM
92integraVTECgsr's Avatar
any codes? check the knock sensor.
Old Nov 27, 2004 | 11:18 PM
old_school_dohcvtec's Avatar
if your vtec lines are blocked, how do you unclog them?
jdm.boi408
Nov 26, 2010 09:53 AM
gsrboost737
Aug 7, 2008 06:38 AM
EGThang
18
Jun 6, 2008 03:26 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
jaydm
12
Apr 7, 2003 09:47 PM
