Belts Squeaking
Old Nov 20, 2004 | 11:02 AM
HJLau75's Avatar
Default Belts Squeaking
I usually try to search for my answers but I couldn't find any this time.
I got a 95 GS-R, when I was changing my ps fluid I got a good amount of it on my ac and ps belts.
Now when i start my car up and turn to get out of the driveway, it makes this loud annoying squeaking noise, it even squeaks when Idle.
I was wonder is there anything I can use to clean and lube them?
Old Nov 20, 2004 | 11:06 AM
PLAGUED_DB7's Avatar
Default Re: Belts Squeaking (HJLau75)
I had the same problem after a puddle of water..I put some bel dreaaing and a lil grease on the pullys with a qtip...
Old Nov 20, 2004 | 12:38 PM
gsrboi80's Avatar
Default Re: Belts Squeaking (PLAGUED_DB7)
Belt dressing or just let it go itll go away eventually
Old Nov 20, 2004 | 01:57 PM
importdude2000's Avatar
same problem right now
it use to only squeek at night when engine is cold..after its hot from driving it would sqeek sometimes
now it sqeeks all night!!!
stupid ps hose leaked right on the belt under it!!!
i was told the belt is glazed
Old Nov 20, 2004 | 06:55 PM
JDAN's Avatar
It may sound a litlle low tech, but its an inexpensive fix if it works.....get a bar of soap and rub it on the belt. Worked for me everytime. Doesn't seem to put any kind of wear on the belt i don't think as i have had the same belts since i owned the car (about 30,000 kms)
MrsR
16
Aug 24, 2013 06:37 AM
Blacknight117
Sep 19, 2011 04:13 PM
FalkenSiR
Aug 3, 2005 09:36 AM
stRtypR25
Sep 26, 2002 03:01 PM
jiggajc
Jun 12, 2002 02:55 AM
