AC Question
Old Jun 25, 2005 | 06:33 AM
VTECisSeXY's Avatar
*insert here*
Default AC Question
Just picked up a 98 4 door and it has a/c but it's just not as cold as it should be. What should I do? Thanks!
Old Jun 25, 2005 | 08:06 AM
gh0st32's Avatar
Default Re: AC Question (VTECisSeXY)
get it recharged
Old Jun 26, 2005 | 12:00 PM
VTECisSeXY's Avatar
*insert here*
Default Re: AC Question (gh0st32)
Ok, so I went and bought one of those do it yourself recharge kits (im sure everyone has seen these) and I went to charge/measure the low side and I saw this <U>BEFORE</U> I started charging.
So, this means my system is charged fully. Correct?
The A/C does blow semi-cold air but I defonetly dont think it's at par with coldness.
What else could be the problem?
Old Jun 26, 2005 | 12:21 PM
confucius's Avatar
drain out the old and put in the new.
if that doesnt work, get a new condensor.
that is what i was told by my mechanic.
but i dont believe him.
he actually made my a/c worse. it was colder before.
but after he re-filled it, it doesnt feel cold for ****.
he told me i need a new condensor.
Old Jun 26, 2005 | 12:57 PM
s2kdre's Avatar
Default Re: AC Question (confucius)
ac compressor might not be turning on check that first
Old Jun 26, 2005 | 03:50 PM
miketegra's Avatar
https://honda-tech.com/zerothread?id=1289571
This is a good place to start....
Old Jun 26, 2005 | 10:43 PM
smkngsr's Avatar
Default Re: (miketegra)
i was wondering if that guage is pretty much similar to any recharge kit that they sell at pepboys because mine does not have a color indicator like his, but it has psi numbers on them...thanks
Old Jun 26, 2005 | 11:31 PM
yrethguad's Avatar
Was your compressor running when your gauge had that reading?
Old Jun 27, 2005 | 04:32 AM
94integragsr's Avatar
Banned
it is because you have moisture in your lines . you need to put the ac system into a vacume for 1 min and then refill this will work i am certafied in ac . them do it your self ac kits are not 100% so you do not get the correct oil to r134 ratio for your ac system any way
slammin86
Mar 9, 2009 01:45 PM
jrs98
Oct 17, 2008 03:51 PM
lovelydc
May 31, 2005 08:26 PM
tofuboi
May 6, 2002 03:01 PM
