ABS Problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR18 »</TD></TR><TR><TD CLASS="quote">You may need to put fluid in the ABS unit... Mine was very low on fluid and it made this annoying vibrating noise.. </TD></TR></TABLE>
mine too...what year is your car? mine is a 95. a couple of my friends with 95's also have this problem.
First thing you need to do is check the error code. Go to this thread and find out how to pull your code: https://honda-tech.com/zerothread?id=978933
I'm just making a guess, but I'm assuming your car is a 94-97. You'll prob throw one of the following codes:
1 3 high pressure leakage
1 8 high pressure system
The cause of this problem is usually a faulty o-ring at the base of your accumulator. This is a very common problem in 94-97 integras. The humming sound that you're hearing is the accumulator attempting to pressurize.
Pull your codes first and then come back. The o-ring fix is under $5 rather than the $800-$1000 to replace the entire ABS unit.
Here's a thread with more info on the accumulator o-ring: https://honda-tech.com/zerothread?id=205285
here you go...check out these links....
https://honda-tech.com/zerothread?id=996524
