Intercooler question for LS integra
Old Nov 16, 2005 | 08:44 AM
gsr dood's Avatar
Default Intercooler question for LS integra
i was wondering if a intercooler is necessary for a turboed ls running around 5-8psi....i searched
Old Nov 16, 2005 | 08:50 AM
sqad_7's Avatar
Default Re: Intercooler question for LS integra (gsr dood)
yes you need one
Old Nov 16, 2005 | 09:07 AM
Kendall's Avatar
Necessary, no.
Recommended, yes.
Old Nov 16, 2005 | 09:29 AM
BrooX's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Necessary, no.
Recommended, yes.</TD></TR></TABLE>
And there are many varieties to chose from as well.
Old Nov 16, 2005 | 09:34 AM
5 Speed AP2's Avatar
Default Re: (Kendall)
Old Nov 16, 2005 | 03:39 PM
gsr dood's Avatar
Default Re: (5 Speed DC2)
for a daily driver would it harm the engine if there was no intercooler? what would hppen? i thought the air goin in would just be warmer wat affect does it have on the engine? i only plan to boost 5-8psi which isnt that much
Old Nov 16, 2005 | 04:02 PM
gsr dood's Avatar
Default Re: (vtecriver)
can anyone say if that is accurate^ i would think detonation would be a cause of a bad tune i wanna know wat happens if i skip puttin an intercooler on
Old Nov 21, 2005 | 03:25 PM
JDM.Jay's Avatar
Old Nov 21, 2005 | 04:11 PM
loudassVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecriver &raquo;</TD></TR><TR><TD CLASS="quote">i forget what its called i think its detenation, but what happens is that the fuel/air mixture in your cylined ignites too early and that can lead to problems</TD></TR></TABLE>
No, this is called pre-ignition. Detonation is uncontrolled burning of the Air/fuel mix, and the flame fronts in the combustion chamber collide, causing extreme heat and impact on the pistons/rods/cylinder walls. It can lead to extreme damage, or a blown engine.
Pre-ignition is caused by hot spots in the combustion chamber lighting off the air/fuel mix, before it compresses and is fired by the spark plug. It can still lead to damage, but is not as bad as detonation.
To prevent both, you need to add fuel, or up the octane rating of the fuel. A more rich mixture will actually run cooler eliminating pre-ignition and helping detonation by providing a more stable air/fuel mixture. You can also retard the timing to get rid of detonation.
Old Nov 21, 2005 | 04:19 PM
Default Re: (loudassVTEC)
But to answer the question about the hot air going into the engine. This warmer air has a big effect on the engine. The warmer air will make it run hotter, as well as make way less power, since the air is less dense. You are actually getting less air per given volume, since the air molecules are farther apart. An intercooler will make way more power, and it'll make conditions in the combustion chamber safer, and more detonation friendly.
novtecnoboost
11
Feb 26, 2007 03:54 PM
spooncivic1
Jul 12, 2006 05:11 PM
(JON)
Dec 7, 2005 06:39 AM
turbochargeb18c
Oct 12, 2005 12:58 PM
P_t0wn
24
Oct 29, 2004 08:08 PM
