Replacin Driver Window ??
Old Nov 16, 2005 | 04:00 PM
Elbowpunk's Avatar
Default Replacin Driver Window ??
Anyone done this before... 91 teg Ls... got broken into... need a window...
anyone kno how to do this ??
Thanks
Old Nov 16, 2005 | 04:03 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Replacin Driver Window ?? (Elbowpunk)
It's very easy. You need to purchase a replacement window (either OEM from the dealer, or aftermarket). OEM is pretty pricey (upwards of $180+) and aftermarket is about $100. Aftermarket is fine, but usually is a little thinner. The aftermarket one I used on my parent's 01 Civic is made in South Africa. Looks fine, but is thinner so the weather stripping doesn't press against all of the window. Rain water will just run down and when you open the window, the weather stripping doesn't wipe the water off. But oh well.
You pop open the door panel (I assume you already know how to do this) and everything else is self explanatory. You remove the old window glass/parts and clean out all the broken glass. There should be a couple of bolts that hold the "clips" that hold the window. The clips are part of the window and will come with the new window.
Loosen the rails on the sides, slide the new window in, bolt the clips in, and then push the rails against the window so it's snug. Then tighen the rails again.
Very easy
Old Nov 16, 2005 | 04:40 PM
Elbowpunk's Avatar
thx... does this matter if its Manual or Electric... cuz i got electronic
Old Nov 16, 2005 | 04:43 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">thx... does this matter if its Manual or Electric... cuz i got electronic</TD></TR></TABLE>
Nope, doesn't matter at all. In fact, electric is easier because removing the manual window crank is a pain in the ***.
You just pull off the door panel and unclip the wiring harness for the electrical components (i.e.: door locks, windows, speakers, etc).
Old Nov 16, 2005 | 04:46 PM
98 Spec R's Avatar
You can buy a used window glass locally from Honda Auto Salvage. They just carry Honda and Acura cars. They have plenty of older Integras. There number is 602-470-0516. They are located on University and 40th St. About 10 - 15 minutes from Ahwatukee. Good Luck.
Old Nov 16, 2005 | 04:52 PM
Elbowpunk's Avatar
Default Re: Replacin Driver Window ?? (98 Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">You can buy a used window glass locally from Honda Auto Salvage. They just carry Honda and Acura cars. They have plenty of older Integras. There number is 602-470-0516. They are located on University and 40th St. About 10 - 15 minutes from Ahwatukee. Good Luck. </TD></TR></TABLE>
ahh thx bro.... i really appreciate it ( sry for SP )..
JDMgunmetalCRX
Mar 31, 2009 08:50 AM
intgraCA
Jun 21, 2007 08:00 PM
intgraCA
May 27, 2006 01:41 PM
C_H_A_D
Dec 7, 2004 09:18 PM
variablevalve
Feb 5, 2004 03:44 AM
