Block heater?
Old Nov 15, 2005 | 03:29 PM
oilguzzler's Avatar
Default Block heater?
Hey i was just wondering if integras came with blockheaters? if not where could i find one and how would i go about installing it? And also, when i pull my ebrake, its often that only the left tire locks up and the right still turns. Is there a way to only tighten one side? thx
Old Nov 15, 2005 | 03:40 PM
thaiphob's Avatar
Nikon!!!
Default Re: Block heater? (oilguzzler)
never came with block heaters.
Old Nov 15, 2005 | 03:45 PM
Finger Lickin' good's Avatar
Default Re: Block heater? (thaiphob)
yes it never came but it was an oem part. Ive seen acura sell them. Its like heating blanket for your engine. You dont plug a cord into your block and magically it warms up.
Old Nov 15, 2005 | 03:46 PM
oilguzzler's Avatar
can i install one?
Old Nov 15, 2005 | 04:04 PM
oilguzzler's Avatar
so it heats the engine while its not running? how much is it? how does it work?
Old Nov 15, 2005 | 04:37 PM
Padawan's Avatar
Darth ModerVader
The heater is an Acura accessory (p/n 08T44-ST7-200) and can be found for roughly $35-$40. It isn't a "heating blanket", it's a heating element that replaces the coolant drain bolt in the block. It's a relatively straight-forward installation, and after it's installed, it is used by simply plugging it in to a household socket. It is intended for areas that experience very cold temperatures, so depending upon where you live, you probably don't need one.
Old Nov 15, 2005 | 04:46 PM
EGDC2CIVIC's Avatar
Default Re: Block heater? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The heater is an Acura accessory (p/n 08T44-ST7-200) and can be found for roughly $35-$40. It isn't a "heating blanket", it's a heating element that replaces the coolant drain bolt in the block. It's a relatively straight-forward installation, and after it's installed, it is used by simply plugging it in to a household socket. It is intended for areas that experience very cold temperatures, so depending upon where you live, you probably don't need one. </TD></TR></TABLE>
here's what it looks like minus the cord, next to the block code plate behind the header
Old Nov 15, 2005 | 07:52 PM
oilguzzler's Avatar
Default Re: Block heater? (EGDC2CIVIC)
Awesome, ya i live in manitoba and winters startin to roll around and its not abnormal to experiance -40 celius days here so i deifently am goin to invest in one.
JO TECH
Apr 30, 2011 04:59 AM
8VEYBEYB
10
Jun 30, 2009 09:04 AM
JFG Kevin
Jul 17, 2006 04:39 PM
T3mp3sT
Feb 23, 2005 03:02 PM
Paprika
Dec 10, 2004 10:24 PM
