da teg ???
Old Nov 18, 2005 | 11:46 AM
kcjohnnyboy's Avatar
Default da teg ???
i was wonderin if the 90-93 integra headers and exhaust were all the same length because i have a 92 gsr with a header and exhaust system and a buddy of mine has a 93 ls and wants to swap the header and exhaust system onto his 93 ls and i was wonderin if the whole header and exhaust system would bolt up
Old Nov 18, 2005 | 11:59 AM
temp's Avatar
Default Re: da teg ??? (kcjohnnyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">i was wonderin if the 90-93 integra headers and exhaust were all the same length because i have a 92 gsr with a header and exhaust system and a buddy of mine has a 93 ls and wants to swap the header and exhaust system onto his 93 ls and i was wonderin if the whole header and exhaust system would bolt up</TD></TR></TABLE>
90-91 is the same length 92-93 is the same length, IE 90-91 DOES NOT = 92-93
Old Nov 19, 2005 | 10:09 AM
so 90-91 is the same and 92-93 is the same, so u are sayin is i can swap a header and exhaust system from a 92 gsr and it will bolt on to a 93 ls
Old Nov 19, 2005 | 10:26 AM
Sic_DA_Nine's Avatar
Default Re: da teg ??? (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 DOES NOT = 92-93</TD></TR></TABLE>
he answered your question
Old Nov 19, 2005 | 12:48 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
90-91 is the same length 92-93 is the same length, IE 90-91 DOES NOT = 92-93</TD></TR></TABLE>
learned that one the hard way...well put
Old Nov 21, 2005 | 09:49 AM
temp's Avatar
Default Re: da teg ??? (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote">
learned that one the hard way...well put </TD></TR></TABLE>
YAY ME!!!!!!
Old Nov 21, 2005 | 10:24 AM
Rajin's Avatar
Well, I am buying a HP Race Header found on this webpage.
http://g2ic.com/forums/showthread.php?t=135164
Will it fit my 92, is it a 92-93 Header Design?
Old Nov 21, 2005 | 10:49 AM
temp's Avatar
Default Re: da teg ??? (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">Well, I am buying a HP Race Header found on this webpage.
Will it fit my 92, is it a 92-93 Header Design?</TD></TR></TABLE>
MOST likely it is due to the O2 sensor location, however those cheap aftermarket brands tend to move that around so its hard to say 100%
sirtef99
K Series
Mar 14, 2019 05:57 AM
19integra94
Apr 16, 2009 08:24 AM
cruizin01
Mar 16, 2009 08:18 AM
jefftron
Jan 25, 2007 07:53 PM
rex_racer728
Mar 24, 2006 09:09 PM
