BOOST!!!!
Old Aug 29, 2006 | 08:20 PM
93_delsol_si_gsr's Avatar
Default BOOST!!!!
OK SO I HAVE A DEL SOL WITH A GSR MOTOR IN IT AND I BOUGHT A TURBO FOR IT... I KNOW VTEC AND TURBO DONT MIX TO WELL BUT IM NOT GANNA DRIVE IT THTA MUCH WHAT WOULD YOU RECOMEND DOIN TO MY CAR PUSHIN ONLY LIKE 5 LBS OF BOOST? I KNOW I NEED PISTIONS AND ALL THE INTERNALS BUT IS THERE ANYTHING ELSE?
Old Aug 29, 2006 | 08:47 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: BOOST!!!! (93_delsol_si_gsr)
Posting without using caps all the time would help..
But running boost on a gsr motor is no big deal, just have it tuned right,
It might have higher compression then an LS, but it's not That high.
Old Aug 29, 2006 | 09:48 PM
Dartanian's Avatar
UNLESS YOU SPECIFY TURBO SIZE, PSI DOESN'T MEAN ANYTHING. VTEC AND TURBO MIX VERY WELL, SO YOU ARE MISINFORMED.
TURN OFF YOUR CAPS LOCK. KTHX.
Old Aug 29, 2006 | 11:03 PM
VHOA's Avatar
assuming you have a smaller turbo i would just run the 5 psi get some higher compression pistons and a good tune and you will have one quick ride
Old Aug 29, 2006 | 11:39 PM
jikespingleton's Avatar
who says u need pistons? ur compression isnt that high, plus 5 psi isnt much for that motor. ur pistons should be fine unless u have a lot of miles. but in any case go with A.R.P. headstuds to ensure a tight fit. extra pressure in the combustion chamber can do alot of damage on a motor that isnt put together well.
Old Aug 30, 2006 | 04:18 AM
GSR DRIVER's Avatar
You need to built your motor with every internal and you can run as much boost as you want! One of my friends just build his H22 in a civic hatch and he is going to run a GT40 turbo with about 22psi of boost and he wont have to worry about anything!
Old Aug 30, 2006 | 07:16 AM
VTECth1s's Avatar
"I KNOW VTEC AND TURBO DONT MIX TO WELL"
you got that all wrong bub, it is a good mix, equals more power, more efficiency which leads to more fun. But you can run 5lbs easily on a completely stock GSR depending on the size of the turbo of course. 5lbs on a big 60-1 turbo is a lot of power compared to a smaller t3/t4 turbo running 5lbs, they both will push out different power and different performance on the same boost level. But with proper tuning and a good fuel management, such as hondata s200w/b, its all about the tune if you want to just run 5lbs on a stock motor.
Old Aug 30, 2006 | 07:19 AM
Schister66's Avatar
Man U FTW
check the sig...you can make good power on the stock engine....
more to come this spring but it might not be on the stock internals anymore
Old Aug 30, 2006 | 10:00 AM
bboysake's Avatar
how can you say vtec and boost dont mix well....
Old Aug 30, 2006 | 11:20 AM
eg4usdm's Avatar
you cant just say, hey im getting a turbo how much psi can run. theres so much more to it. you need to read up a little bit about what your doing before you get mommy and daddy's credit card. i would get you some links but i think honda-tech is fucked up or something right now
Old Aug 30, 2006 | 12:22 PM
one of my friends told me that vtec an boost arent good together thank you for letting me know!!! its a 72 mm turbo... i have to tune my ecu right?
Old Aug 30, 2006 | 12:34 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: (93_delsol_si_gsr)
does you friend even own a honda? vtec and turbo dont mix HAHA if your only runnin 5 pounds i dont think you have to worry about upgrading the internals, take it to a good tuner.
Old Aug 30, 2006 | 01:30 PM
DS002's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_delsol_si_gsr &raquo;</TD></TR><TR><TD CLASS="quote">one of my friends told me that vtec an boost arent good together thank you for letting me know!!! its a 72 mm turbo... i have to tune my ecu right?</TD></TR></TABLE>
72 mm ....... ha
Old Aug 30, 2006 | 01:39 PM
copsloveme's Avatar
BOOST AND VTAK ARE A NICE MIX ITS JUST A MYTH, THAT THEY DON'T LIKE EACH OTHER AND BTW CAPS IS CRUISE CONTROL FOR ZHE COOL
Old Aug 30, 2006 | 01:47 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
u will be cool with 5lbs on stock internals. thats with a small turbo like a t3/t4.
Old Aug 31, 2006 | 06:04 PM
Default Re: (copsloveme)
no thank ypu i love my del sol its realy light and i want to be different. but it looks like a fun project why dont you put money into it?
Old Aug 31, 2006 | 07:15 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_delsol_si_gsr &raquo;</TD></TR><TR><TD CLASS="quote">no thank ypu i love my del sol its realy light and i want to be different. but it looks like a fun project why dont you put money into it?</TD></TR></TABLE>
Del Sols aren't as light as you might think. Have to add a lot of weight to strengthen the chassis when you take the top off a car.
Smily0087
Mar 20, 2010 05:37 PM
b18-crx
Jul 11, 2009 02:00 PM
Bonestock98GS
Apr 9, 2009 07:43 PM
92civtegra
Aug 15, 2007 08:26 PM
vtec25
Jun 5, 2006 12:30 AM
