Help! Removing shift rod
Old Aug 28, 2006 | 09:10 AM
chu77's Avatar
Default Help! Removing shift rod
How do you remove the spring pin? I need to remove the shift rod for my swap.
Do you hit it out from the bottom? What tools do I use?
Old Aug 28, 2006 | 11:52 AM
PrinceAli132's Avatar
Default Re: Help! Removing shift rod (chu77)
The infamous bitch pin. I believe the tool needed to remove that is called a pin punch or something along those lines. https://honda-tech.com/zerothread/1719892 That link has the correct name for the tool. Also, to make it easier to remove the shift linkage from the shifter then once you have the tranny out you'll have more room to work on removing the pin.
Ali
Old Aug 28, 2006 | 12:05 PM
Sam92Teg's Avatar
Default Re: Help! Removing shift rod (PrinceAli132)
You can leave it attached to the tranny and disconnect it from the shifter, then once the tranny is removed, you will have room to knock the bitch pin out.
Edit: damn, I just read the final line of the previous post, my bad, same advice
Ali, we almost used the same exact words, that is too freaky.
Old Aug 28, 2006 | 01:30 PM
91turboteg's Avatar
All you need is an air hammer and the right size bit.
hold a towel on the other side or you will lose the pin,
just hit the trigger and its out.
ryc555
Jul 14, 2007 10:46 PM
say_xiong
Sep 21, 2006 11:34 PM
dynomax27
Aug 23, 2003 01:57 PM
leprechan117
10
Apr 12, 2003 04:02 AM
MeanGreenEG9
Mar 14, 2003 10:33 AM
