starter
Old Aug 27, 2006 | 08:23 PM
soon2bdropped's Avatar
Default starter
what tools are needed 2 change the starter? and is there DIY? thanks
Old Aug 27, 2006 | 08:24 PM
Dartanian's Avatar
Default Re: starter (soon2bdropped)
Basic hand tools. There are two bolts holding it on. Remove those and unplug the starter terminals. Replace in reverse order.
Old Aug 27, 2006 | 08:50 PM
Default Re: starter (Sleeper Style)
what size.. because i have open end wrenches here maybe i can use it.. also i disconnect battery right?
also why doesn;t my starter grind when i try to start it instead of click click?
i think its not grinding because the teeth is still good on flywheel.. but why is the click click?
Old Aug 28, 2006 | 09:08 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Just use your bare hands, that's what chuck norris does, he doesn't use tools he uses his fingers, and if the bolt doesn't want to come off he threatens it.
Old Aug 28, 2006 | 10:13 AM
Default Re: starter (Kiniku Chunks!!!)
not funny
Old Aug 28, 2006 | 10:15 AM
94_DC4's Avatar
They are 14mm or 17mm bolts if I remember correctly.
Old Aug 28, 2006 | 10:35 AM
Sam92Teg's Avatar
Default Re: starter (SiRGDC)
You will need the sockets, extensions, and a ratchet. I don't think you will be able to use the wrenches.
If you are only getting a 'click, click' when trying to start, check the connections first, both at the battery and at the starter. Make sure your battery is fully charged, just checking if the headlights work isn't enough. When an insufficient current attempts to engage the starter, you can often hear the sound you are getting.
Old Aug 28, 2006 | 10:58 AM
Default Re: starter (Sam92Teg)
does anyone have a manual or DIY so i can do it thanks..
Old Aug 29, 2006 | 09:57 AM
is a 6" extension good what about 10?
ttt for manual or DIY..
Old Aug 29, 2006 | 10:53 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
disconnect battery (unless you like to see sparks fly ), remove electrical connections from starter, remove 2 bolts holding it on, installation is the reverse of removal.
That's pretty much the jist of it.
Old Aug 29, 2006 | 11:57 AM
Wayne_Curr's Avatar
Default Re: (PatrickGSR94)
hondahookup.com
Get yourself a helms on there. Its seriously freaking easy, 30 minutes of work TOPS if you have to learn how to use a ratchet first.
Old Aug 29, 2006 | 12:39 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">ttt for manual or DIY..</TD></TR></TABLE>
you really dont need one, theres really only 2 bolts and a wire from the battery. if you have any mechanical know how itll only take 30 minutes.
Old Aug 30, 2006 | 09:14 PM
Default Re: (Wayne_Curr)
anybody got a site that shows u how the internal of the starter and how it works.
Old Sep 1, 2006 | 02:12 PM
Default Re: (soon2bdropped)
i'm proud of myself.. because i installed a new starter wit basic tool that might of taken 2 1/2" hrs but i still did it... i'm very glad and it was a good learning experience.
however there was a few things that slow me down.. one bolt was longer on one side.. which took me forever because i was using closed end wrench.......
overall what i did was disconnect the batt wit a 10mm wrench took off my short ram intake... took the power wire off with a 14mm.. remove intake for more room.. okay located the bolts... found them... reinstall in reverse order.. next time this should only take me 10 mins wit the correct tools instead of 2 1/2 hrs..
thanks honda tech couldn't do it without y'all
miguey310
Jun 23, 2010 06:14 PM
Mdg5858
Feb 9, 2009 12:08 PM
Touge Tuning
May 3, 2006 11:14 AM
Chairman Kaga
Oct 28, 2002 04:23 PM
kento
Jul 13, 2001 09:45 PM
