iab
Old Aug 30, 2006 | 11:38 AM
Frisco-EG6's Avatar
Default iab?
basically i just bought a 95 b18c1 motor and i notice it didn't come wit this iab box but the solenoid is still there wit the vacuum lines hooked up to it. is it possible to run like this still. i did search but didn't find an answer to this.
Old Aug 30, 2006 | 02:17 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: iab? (Frisco-EG6)
What exactly are u asking? Do u want to run with it or without it?
Old Aug 30, 2006 | 08:13 PM
Frisco-EG6's Avatar
Default Re: iab? (rukawa1one)
oh yea sorry bout that i wanted to know if i can run the motor without the black canister and of course i am runnin the stock manifold.
Old Aug 30, 2006 | 08:31 PM
lVlemphizStylez's Avatar
you can...but obviously your secondaries wont function properly...they will probably in all likelihood remain in the open position
Old Aug 30, 2006 | 09:05 PM
Frisco-EG6's Avatar
Default Re: iab? (lVlemphizStylez)
Old Aug 30, 2006 | 09:18 PM
Frisco-EG6's Avatar
the way mine is set up is #15 hose comes off the #3 t-fitting where #14 and #4 used to be and runs to the#6 solenoid where the #9 hose is supposed to go. and everything else is the same. my question is, is it ok to run like this? what is the cause and effect? or will the secondaries stay open as lVlemphizStylez stated.
Modified by Frisco-EG6 at 10:29 PM 8/30/2006
Old Aug 30, 2006 | 09:37 PM
rukawa1one's Avatar
I would set it up the way it was meant to be. If the IAB is not connected the the secondaries will stay open, and it could affect the idle. If u dont want to use the IAB then get like a skunk2 manifold and and ECU that doesnt have the IAB control
Old Aug 30, 2006 | 09:38 PM
it does not affect the idle at all...
Old Aug 30, 2006 | 10:13 PM
DC2SIR-G's Avatar
* B A N N E D *
u can run like that but it will run shitty. you will lose tons of torque and midrange power because they stay open. i have that IAB box PM me if you want it ill give it to u for cheap
Old Aug 31, 2006 | 11:27 AM
Frisco-EG6's Avatar
Default Re: iab? (DC2SIR-G)
thanks 4 the input everybody
Old Aug 31, 2006 | 11:40 AM
Frisco-EG6's Avatar
just a thought if the secondaries stay open meaning more air coming in can't i just up the fuel pressure a little to compensate for the air coming in. or would that be a bad idea? also i don't have enough money 4 a manifold rite now, but when i do i will get one! worse comes the worse i'll just get the iab box.
Old Aug 31, 2006 | 01:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frisco-EG6 &raquo;</TD></TR><TR><TD CLASS="quote">just a thought if the secondaries stay open meaning more air coming in can't i just up the fuel pressure a little to compensate for the air coming in. or would that be a bad idea?</TD></TR></TABLE>
if only the logic behind fluid dynamics was that simple....no it doesnt work like that...think about what you do when the secondaries open....think pipe length diamter...and velocity of a fluid
Old Aug 31, 2006 | 04:10 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frisco-EG6 &raquo;</TD></TR><TR><TD CLASS="quote">just a thought if the secondaries stay open meaning more air coming in can't i just up the fuel pressure a little to compensate for the air coming in. or would that be a bad idea? also i don't have enough money 4 a manifold rite now, but when i do i will get one! worse comes the worse i'll just get the iab box.</TD></TR></TABLE>
You need turbulence in the air flow to mix the fuel with the air. The IABs allow for adequate turbulence without excessive flow restriction.
Old Aug 31, 2006 | 04:27 PM
DC2SIR-G's Avatar
* B A N N E D *
if your motor is has st ock internals... getting an IAB box would be your best purchase. getting a single runner manifold will slow u down without any headwork. i've been in your situation before, and purchasing the IAB box was well worth it
Old Sep 1, 2006 | 11:17 AM
Frisco-EG6's Avatar
thanks again everybody for all the input!
im bout to go buy the iab box today
Old Sep 5, 2006 | 08:22 PM
Frisco-EG6's Avatar
i bought the iab box but now i don't have #4 the check valve, is it possible to run without this or should i just buy one.
Old Sep 6, 2006 | 04:10 AM
Dogginator's Avatar
Daisy... Daisy...
The check valve is essential for the vacuum canister to store vacuum.
Old Sep 6, 2006 | 10:49 AM
Frisco-EG6's Avatar
Default Re: iab? (Dogginator)
right on
potatointegra01
May 20, 2015 12:36 PM
coronadrinker
Aug 31, 2006 01:33 PM
Frisco-EG6
Aug 30, 2006 04:10 AM
FastNFurious
Aug 28, 2003 11:10 AM
