Check engine light: Code P1457
Old Aug 29, 2006 | 08:32 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Check engine light: Code P1457
As stated throwing a code p1457.
From what I have got so far its a emissions code, which is unable to pull vacuum in tank.
Which part is it talking about?
What parts do I need to fix it?
How hard is it to fix?
TIA!
Old Aug 29, 2006 | 08:54 PM
Yambor's Avatar
* EVAP canister is leaking, damaged or full of water
* EVAP canister purge line is loose, damaged or blocked
* EVAP two-way valve or ORVR vent shut valve is damaged
* EVAP fuel tank vapor control valve is damaged or has failed
* PCM has failed
Detected (Canister Area) Cold startup completed (IAT sensor signal from 32-86�F at engine startup), vehicle driven at over 5 mph for over 2 minutes, then with ECT sensor signal more than 154�F and the EVAP Control and Vent solenoids enabled, the PCM detected the fuel tank pressure was incorrect due to a leak in the canister area during the Leak Test.
This code sets in 2 Trip(s).
Old Aug 29, 2006 | 09:30 PM
B18C Turbo's Avatar
so does this mean OBD-1 owners CANNOT remove thier emissions crap?
Old Aug 29, 2006 | 09:41 PM
HT Black OPs
Default Re: (B18C Turbo)
thanks yambor. How much should this cost at a shop? Looking to get a full-service ckeck as well.
Old Aug 30, 2006 | 08:12 AM
Yambor's Avatar
Default Re: (00IntegrAllmotoR)
depends on how long it takes to diagnose it. usually they will charge you to pull the code. then diagnose it, it should take a good tech less than an hour to find out where its leaking
Old Aug 30, 2006 | 02:26 PM
HT Black OPs
Default Re: (Yambor)
Well I had autozone pull the code for me for free. Thats the only reason I know about it.
Old Aug 30, 2006 | 08:48 PM
HT Black OPs
Any chance I could fix this problem myself?
Have some mechanic skills.
Duke of Dull
Honda Civic (2001 - 2005)
28
Jul 15, 2019 02:43 PM
Eddie99
Honda S2000
Nov 7, 2007 09:31 PM
1998_4dr_gsr
Oct 27, 2006 03:21 PM
1998_4dr_gsr
Jan 24, 2006 05:03 PM
vtecdc2
Jul 16, 2002 08:32 AM
