Valve adjust.
Old Aug 29, 2006 | 04:05 PM
Honda_Accord's Avatar
Default Valve adjust.
http://www.c-speedracing.com/h...t.php
ok i found that link but it says b18c , im trying to do one for a b18b (94 integ) i knwo it says "follow for all other b18's" just making sure.. dont wanna f nothing up
Old Aug 29, 2006 | 05:18 PM
Circuit Star-29's Avatar
Default Re: Valve adjust. (Honda_Accord)
The method is the same...
I recommend removing your spark plugs to make your life easier.
Old Aug 31, 2006 | 06:52 PM
CASTUDILLO01's Avatar
SAME STEPS BUT THE VALVE CLEARANCES MAY BE DIFFRENT BETEEN B18b AND B18C. CALL THE DEALER TO MAKE SURE BUT THESE CEARANCE SHOULD BE WHAT YOUR LOOKING FOR. Intake 0.15 - 0.19 mm (0.006 - 0.007 in)
Exhaust 0.17 - 0.21 mm (0.007 - 0.008 in)
Old Aug 31, 2006 | 08:25 PM
BLacK FirE's Avatar
Default Re: Valve adjust. (CASTUDILLO01)
For a b18b, the valve clearances are:
INTAKE: 0.003" - 0.005" (0.08mm - 0.12mm)
EXHAUST: 0.006" - 0.008" (0.16mm - 0.20mm)
Also with the b18b, which is not mentioned on the cspeedracing guide, is you do not need the bent wrench. A regular wrench will do.
highliner82
Dec 10, 2010 09:31 AM
bara6075
Dec 9, 2007 10:42 PM
Octoman
May 20, 2004 03:12 PM
vaporboy12
Dec 30, 2003 09:22 PM
MrEg
Sep 20, 2003 01:18 AM
