dc shocks on da?
Old Mar 5, 2008 | 10:05 PM
vdawg559's Avatar
Default dc shocks on da?
does any one knows if it fits?
Old Mar 5, 2008 | 10:32 PM
denraweb's Avatar
Default Re: dc shocks on da? (vdawg559)
Yessir, believe it does bop. At least I know the front should fit. Correct me if I'm wrong anyone...
Old Mar 5, 2008 | 10:51 PM
vdawg559's Avatar
wahhhhhhhh phill hahahahahha.. some one let me know tho. ima bout to pick up some springs an shocks. 40 bucks. an want to know if dey fit. i dont wanna spend outragous price. like autozone hahahahhaha. even tho i get 20%
Old Mar 5, 2008 | 10:59 PM
dumada9's Avatar
Default Re: (vdawg559)
i believe the back should fit fine but for the front you'll need the dc front forks
Old Mar 5, 2008 | 11:01 PM
vdawg559's Avatar
yeah. i have a feelling the back should be very easy. if i put the dc front fork. would it b lil higher. or teh same?
Old Mar 5, 2008 | 11:56 PM
dumada9's Avatar
i think the dc shocks are shorter??
Old Mar 5, 2008 | 11:57 PM
DVSBIZZYB's Avatar
Yeah you can use the EG/DC shocks on the DA. Make sure you have the EG/DC forks. You need the forks because the DC shocks are wider than the DA shocks.
Old Mar 6, 2008 | 12:22 AM
dumada9's Avatar
Default Re: (DVSBIZZYB)
that back fits on perfectly thought right, all you need is the front forks to make it work?
Old Mar 6, 2008 | 06:16 AM
be18see1's Avatar
Default Re: (dumada9)
im running dc shocks on my da. the rear shocks are a bolt up affair but the front will require either dc or eg front forks. i went with eg forks bc theyre easier to find at pick n pull. youre going to want to get some sleeve coilovers bc the back shocks are shorter, but the front are taller and it shows if you leave on the stock dc springs. i have ground controls on stock dc shocks with the rear as tall as they go and the fronts about 1/4 of the way down. my car is about a 1/2" from tucking tire. i like this set up bc i think its easier on the shocks and i got pretty low. i could go lower but i like to play it safe.
Old Mar 10, 2008 | 03:45 AM
vdawg559's Avatar
so i would need
dc/eg front forks.
thanks guyz. im gonna get them shocks....
I LUV MY EJ1
Apr 24, 2009 05:07 PM
bluestd
Apr 21, 2009 10:10 PM
Soichiro's way@MF
Suspension & Brakes
Mar 20, 2007 12:36 AM
EK k kay
Apr 7, 2005 08:20 AM
