hard shifting
Old Mar 2, 2008 | 06:15 PM
94DB8's Avatar
Default hard shifting
it was hard shifting into gears so i changed my tranny fluid to HG MTF and it didnt help ... now its getting even harder to change gears but theres is no grinding noise. im pretty sure it shouldnt be like this, but is it normal with this type of shift linkage versus a cable system?
Old Mar 2, 2008 | 06:40 PM
blkb18's Avatar
Default Re: hard shifting (94DB8)
check your shift linkage bushings and also make sure the linkage isnt bent.
Old Mar 2, 2008 | 06:52 PM
94DB8's Avatar
alright ill check that ,, it shouldnt be that tho cuz it only does it when im driving .. i know i put enough fluid in there cuz it started to come out of the fill plug when i changed it.
Old Mar 2, 2008 | 07:03 PM
HONDACURA-DB8's Avatar
Default Re: (94DB8)
Here's a wild guess, your clutch disc is bad. The spring may have popped out and is stuck between the disc and pressure plate causing it hard to get into gears.
Old Mar 2, 2008 | 07:12 PM
94DB8's Avatar
^^^^^sounds like a good excuse to get a new clutch
Old Mar 2, 2008 | 11:32 PM
D@9 A.D.B.'s Avatar
Default Re:
[QUOTE=HONDACURA-DB8]Here's a wild guess, your clutch disc is bad.QUOTE]
thats exactly what i was thinking...i mean it is a 94 when is the last time the clutch was changed?
Old Mar 3, 2008 | 05:18 AM
94DB8's Avatar
your probably right but its not slipping .. would it still cause this type of problem?
Old Mar 3, 2008 | 05:54 AM
96cgpteg's Avatar
Default Re: (94DB8)
Im having this same problem. all within the last couple months ive put a new clutch in, new cmc and slave cylinder, mtf has been flushed several times, ive looked over the linkage.. my hard shifting will come and go. i can shift through the gears fine some times smooth as butter, then all of the sudden it will feel like total slop going into gear. I want to hope that its just some air in my system, but ive bled it out several times.. this is starting to get frusterating
Old Mar 3, 2008 | 08:02 AM
94DB8's Avatar
sorry to hear about that the only left would something INSIDE the tranny itself ...
anyone other suggestions?
Old Mar 3, 2008 | 03:29 PM
94DB8's Avatar
bump
Old Mar 3, 2008 | 04:27 PM
racebum's Avatar
Default Re: (HONDACURA-DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDACURA-DB8 &raquo;</TD></TR><TR><TD CLASS="quote">Here's a wild guess, your clutch disc is bad. The spring may have popped out and is stuck between the disc and pressure plate causing it hard to get into gears.</TD></TR></TABLE>
This just happend to me a couple days ago. The cheapo clutch that was installed before i bought my dc2 had this slice of metal fall out when it was pulled apart. the metal chunks would wedge between the disc and plate and cause all sorts of issues, shaking on take off, hard shifting etc. Bought a new Exedy stage 1 clutch kit and resurfaced my flywheel. Drives like a dream now.
Old Mar 3, 2008 | 08:51 PM
jr408's Avatar
you prolly need a new tranny...go get it checked you might have an internal problem...
Old Mar 4, 2008 | 07:34 AM
94DB8's Avatar
ok cool looks like i need a new clutch
Old Mar 4, 2008 | 08:23 AM
jr408's Avatar
Default Re: (94DB8)
if its not grinding why are you going to get a new clutch???you might have an internal problem...go to a shop and have it checked before you waste your money and buy something you dont really need
Old Mar 4, 2008 | 08:48 AM
super jdm yo's Avatar
Default Re: (jr408)
yeah i had that problem with my old transmission. i switched it out and gave my old one to a friend that rebuilds transmission. he told me that when he opened up my old transmission the bearings were pretty much gone and he could really only salvage the housing.
Old Mar 4, 2008 | 02:53 PM
94DB8's Avatar
jr408&gt; i may have a spring that came out of my disc and its starting slip on the top end so i would be killing two birds w/ one stone,, what would the tranny shop tell me that i already dont know? its hard shifting and may be an internal problem.
graftuner34
Feb 28, 2007 12:56 PM
AwOrKiNpRoGrEsS23
Aug 29, 2006 11:19 AM
JFG Kevin
May 7, 2006 12:12 PM
PAID-$$$
Jun 11, 2004 12:50 PM
TurBoXBirD16
Aug 28, 2002 02:46 AM
