BIG!!!!!! headlight problem
Old Mar 4, 2008 | 01:13 PM
StreetRiot_DRE's Avatar
Default BIG!!!!!! headlight problem
I have a 1995 integra and one day my low beam light was flickering on and off. Then a couple days later it just stopped working. Then a couple days later the other side low beam stopped working. So i tried fixing it and it ended up losing another light my left high beam. So know i had both low beams that dont work and my left high beam not working. I know its not the bulbs bc i checked them. I also checked the wire with a test light and no power in any of the three. So hopefully someone can tell me what to do to get it to work because it is really annoying......
Old Mar 4, 2008 | 01:15 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: BIG!!!!!! headlight problem (StreetRiot_DRE)
What bulbs are your running? Have you inspected the plugs?
Old Mar 4, 2008 | 01:17 PM
Default Re: BIG!!!!!! headlight problem (Dogginator)
9005 regular sylvania bulbs and i checked the plugs and the wires
Old Mar 4, 2008 | 01:20 PM
Dogginator's Avatar
Daisy... Daisy...
Check the grounds and verify 12V at the harness. If 12V is not present, check the switch, etc.
Old Mar 4, 2008 | 02:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Check the grounds and verify 12V at the harness. If 12V is not present, check the switch, etc.</TD></TR></TABLE>
Switch is fine, nd i doubt thatd be it cuz only 3 out of four lights lost power....no power at tha Bulb harness, or where on tha harness are you referin to??
Old Mar 4, 2008 | 03:51 PM
Blahblah718293's Avatar
please tell me you checked the fuses.
Old Mar 4, 2008 | 07:16 PM
Default Re: BIG!!!!!! headlight problem (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">please tell me you checked the fuses.</TD></TR></TABLE>
tha fuses were tha first thing checked, nd checked every time i've tryed figureing this problem out
James Walsh
Honda Civic (2001 - 2005)
Jun 8, 2019 06:41 AM
StreetRiot_DRE
Lighting
Mar 6, 2008 11:49 AM
Jacen
Mar 22, 2006 10:51 PM
gsr-2nr
Jul 18, 2004 04:52 PM
