Engine ID location
Old Mar 4, 2008 | 10:56 AM
bacon117's Avatar
Default Engine ID location
I'm not sure whats going on, the car cranks, but wont start, and there is this piece of rod shaped metal sticking out of the oil pan, whats going on?
haha, only kidding. My question is on the ID plat of honda engines. I have a B16A1 to go back in my 1gen teg, but i'm having trouble figuruing out what is currently in there. The normal ID plate near the engine trans interface is missing. It looks as if it was cast WITHOUT the plate even there. It doesn't look ground off, just simply not there.
Anyone run across this before?
Modified by bacon117 at 12:08 PM 3/4/2008
Old Mar 4, 2008 | 11:21 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Engine ID location (bacon117)
It should be stamped. The VIN plate is riveted to the block on some engines.
Old Mar 4, 2008 | 11:34 AM
bacon117's Avatar
Default Re: Engine ID location (Dogginator)
That is whats weird, it's not stamped, flat area where the stamp should be isn't there either. Where would the vin be rivited?
Old Mar 4, 2008 | 11:49 AM
DA_9's Avatar
Take a pic and show us, take a pic of the stamp, where it should be. Take a pic of the engine, is it SOHC or DOHC, do you KNOW how to tell? Is it vtec; does it have a solenoid for vtec? Look at the head....on the front side of it under the valve cover where the actual head is you can see a stamp. I have a GSR head, it is stamped as p72-1. it should be above the headers, to the left, below the valve cover. Remember to take pics!
Old Mar 4, 2008 | 12:16 PM
bacon117's Avatar
Default Re: Engine ID location (DA_9)
I'm an automotive engineer, I hope I can tell the difference from SOHC and DOHC.
Just looking for a yes or no... Yes, I have heard of an ID plate not bieng there, and here is why. OR NO, i have not heard of one, you are on your own.
Thanks, have a nice day.
Modified by bacon117 at 1:30 PM 3/4/2008
Old Mar 4, 2008 | 12:33 PM
Dogginator's Avatar
Daisy... Daisy...
Some replacement engines are not stamped with an engine ID number, but they still are stamped with the engine type. Perhaps the cylinder block was replaced.
SolAssassin
Dec 15, 2016 04:45 PM
724chris
11
Aug 8, 2009 09:42 PM
Pablo Escobar
May 3, 2006 03:02 PM
gsrvx
Aug 22, 2002 01:25 PM
