should i get a breather?
Old Jan 9, 2004 | 09:38 PM
superstud's Avatar
Default should i get a breather?
i'm planning to do my turbo install in about a month. i've been looking at lots of pics of turbo setups and have tried to find threads but i can't really tell if most people use valve cover breathers or hook up the pcv hose to the intake pipe like it's supposed to be.
which way is better and why?
Old Jan 10, 2004 | 09:39 AM
superstud's Avatar
bump!
Old Jan 10, 2004 | 09:46 AM
B18bEK's Avatar
just get a catchcan setup
Old Jan 10, 2004 | 10:42 AM
Ls-Rturbo's Avatar
Default Re: should i get a breather? (superstud)
a breather filter will make ur engine bay get dirty faster just take large vacume or fuel hose and run down the back of ur motor so it dumps on the ground. thats what i got on my 1.8T and it works fine.
Old Jan 10, 2004 | 09:58 PM
superstud's Avatar
not back to the charge pipe before the TB?
Old Jan 11, 2004 | 08:53 AM
4U2NV's Avatar
Default Re: (superstud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superstud &raquo;</TD></TR><TR><TD CLASS="quote">not back to the charge pipe before the TB?</TD></TR></TABLE>
No you can't do that with turbo because you will rob yourself of boost... If oyu run it back to the intake pipe it has to be the one before the turbo, not the charge pipe...
Old Jan 11, 2004 | 12:17 PM
superstud's Avatar
ok i've looked closely at a few more pics, and it seems like a lot of people go back to the same spot just before the TB.
wouldn't connectiong it before the turbo get your compressor side all dirty from the fumes and **** that come out of the pcv hose?
Old Jan 11, 2004 | 12:25 PM
mamaboy's Avatar
or just go with an endyn catchcan setup
Old Jan 11, 2004 | 02:57 PM
johnsona's Avatar
Old Jan 11, 2004 | 03:27 PM
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">
No you can't do that with turbo because you will rob yourself of boost... If oyu run it back to the intake pipe it has to be the one before the turbo, not the charge pipe...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnsona &raquo;</TD></TR><TR><TD CLASS="quote">hook up the pcv hose to the intake pipe like it's supposed to be.</TD></TR></TABLE>
you also do not want to be putting positive pressure into the crankcase
Old Jan 11, 2004 | 04:22 PM
Ls-Rturbo's Avatar
Default Re: should i get a breather? (Boltz)
how would it rob u of boost if it dosent go in to the pipe befor the TB?
Old Jan 11, 2004 | 10:10 PM
superstud's Avatar
i can't see robbing it of boost. maybe a split second of lag while the crankcase fills up, but that's a pretty tiny hole compared to the TB.
so is there a final answer here? i don't really know anything about a catch can setup. haven't read up on them. maybe in the future.
until then, WHAT SHOULD I DO?
Old Jan 11, 2004 | 10:58 PM
JonGP4's Avatar
you don't want to have positive pressure in your crankcase.. thats the whole reason that hole is there.. to relieve the pressure.. i don't have mine hooked up to anything.. i hasn't gotten dirty anywhere.. i guess it just depends on how much blowby you have
Old Jan 12, 2004 | 08:02 AM
4U2NV's Avatar
Default Re: should i get a breather? (bl18t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl18t &raquo;</TD></TR><TR><TD CLASS="quote">a breather filter will make ur engine bay get dirty faster just take large vacume or fuel hose and run down the back of ur motor so it dumps on the ground. thats what i got on my 1.8T and it works fine.</TD></TR></TABLE>
Yes if you don't have a intake pipe to run it back to, just run a hose off the valve cover and have it dump to open atmosphere...
Old Jan 12, 2004 | 08:21 AM
superstud's Avatar
ok i guess i'll do that. thanks guys!
WH0R3nEF9
Mar 14, 2005 10:01 PM
See Are X
Feb 5, 2005 08:44 AM
B18B1DOHC
Dec 20, 2003 02:09 AM
mskibbz-T
Jul 9, 2003 04:21 PM
Flamenco-T
Nov 18, 2001 01:17 PM
