Oil Return Line
Old Jan 8, 2004 | 06:09 PM
FOrSfEd's Avatar
Default Oil Return Line
Just wondering if anyone uses a small gasket between the oil return line and the place on the turbo that the oil line goes. For some reason mine keeps leaking alot of oil.
Old Jan 8, 2004 | 06:12 PM
redboost10's Avatar
Default Re: Oil Return Line (FOrSfEd)
yes a gasket is needed there
Old Jan 8, 2004 | 06:15 PM
FOrSfEd's Avatar
Default Re: Oil Return Line (tgh99si)
Anyone know where I can get one.
Old Jan 8, 2004 | 06:40 PM
turbotypeR@SPEC's Avatar
25 Year Member
any turbo company should have them.if not,you can get gasket material from a local parts store and cut one out yourself with a razor blade
Old Jan 8, 2004 | 07:43 PM
Del_Slowest's Avatar
Default Re: Oil Return Line (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">any turbo company should have them.if not,you can get gasket material from a local parts store and cut one out yourself with a razor blade</TD></TR></TABLE>
right on, make it from gasket paper from autozone or wherever
Old Jan 8, 2004 | 07:44 PM
Flamenco-T's Avatar
give me your address, I'll send one over to you tmw
stan
Old Jan 8, 2004 | 07:45 PM
DaveF's Avatar
Default Re: Oil Return Line (Del_Slowest)
if not than the hi-temp silicone will do the job(the orange stuff) permatex..be sure to allow it to dry/cure completely before running the car.
Old Jan 8, 2004 | 07:55 PM
BoostedSi's Avatar
Default Re: Oil Return Line (2.2Lcivic)
i thnk i've even used hondabond on it before.
Old Jan 9, 2004 | 04:22 AM
FOrSfEd's Avatar
Default Re: Oil Return Line (BoostedSi)
Yeah I tried hondaban but it didn't hold to well. Thanks alot everyone or all your help, I'll let you know the outcome.
Old Jan 9, 2004 | 04:28 AM
BROOD's Avatar
I usually get good results from using the gasket and a thin coating of Hondabond on each side.
Old Jan 9, 2004 | 05:00 AM
incogNitto's Avatar
Default Re: Oil Return Line (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">give me your address, I'll send one over to you tmw
stan</TD></TR></TABLE>
Stan will hook you up , if not you can get one at http://www.atpturbo.com/Mercha...e=OIL
Old Jan 9, 2004 | 05:30 AM
Bailhatch's Avatar
Default Re: Oil Return Line (incogNitto)
I use high temp silicon. no problems on a few diffrent cars.
Old Jan 9, 2004 | 07:26 PM
FOrSfEd's Avatar
Default Re: Oil Return Line (Bailhatch)
I did use the high temp for now, and it seems to be holding good so far.
Old Jan 9, 2004 | 08:21 PM
wanksta
Guest
Posts: n/a
i got the same problem, but its not bad. im making my mech. fix it
Old Jan 9, 2004 | 08:29 PM
rjardy's Avatar
Default Re: (wanksta)
I was actually thinking about o-ringing that on the milling machine. What do you guys think?
Rob
Old Jan 9, 2004 | 09:21 PM
rtype11's Avatar
Default Re: (rjardy)
dont bother o ringing that , remember there is like 0 pressure there, the oil return line is "honda tech" for sink drain pipe. PS the flange has a round orifice but the CHRA is rectangular, good luckcutting an O ring.
Old Jan 10, 2004 | 06:15 PM
technician 419's Avatar
if you need the gasket the are available on our site under forced induction http://www.import-palace.com
Old Jan 10, 2004 | 07:01 PM
FOrSfEd's Avatar
Default Re: Oil Return Line (technician 419)
Thanks alot
Old Jan 10, 2004 | 07:06 PM
rjardy's Avatar
Default Re: (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">dont bother o ringing that , remember there is like 0 pressure there, the oil return line is "honda tech" for sink drain pipe. PS the flange has a round orifice but the CHRA is rectangular, good luckcutting an O ring. </TD></TR></TABLE>
hey guess what genius, just because its not round does not mean you cant mill an oring into it. I guess you have never had the fast idle valve apart on your honda. Damn some people are so close minded. I think I am going to do it just for gee whiz factor now...
Rob
Old Jan 11, 2004 | 01:33 AM
rtype11's Avatar
dude I do not appreciate your tone, I try to be helpfull and save you time and effort on an item that does not need O-ringing, sure you can make a receiver groove in the CHRA good luck not cutting over the egdes hope you dont ruin your turbo, I dont run a FIT valve neither and wouldnt O-ring one anyway - why?? for "gee whiz factor", just head and block is worth the time and effort.
Old Jan 11, 2004 | 05:32 AM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incogNitto &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.atpturbo.com/Mercha...e=OIL </TD></TR></TABLE> just got my gasket....
Old Jan 11, 2004 | 10:16 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot</TD></TR></TABLE>
I sent your gasket out...
Old Jan 11, 2004 | 10:24 AM
FOrSfEd's Avatar
Again thanks alot stan
toolowsol
Aug 15, 2005 02:02 PM
Fatty_1775
Jul 3, 2005 08:36 PM
GPoodle
Nov 15, 2003 04:05 PM
highmilehatch
Apr 8, 2003 07:16 PM
