Your thoughts on Royal Purple
Old Jan 9, 2004 | 11:18 AM
tthame1's Avatar
Default Your thoughts on Royal Purple
How many of you have used royal purple? I've been using Mobil 1, but I've heard some pretty good things about Royal Purple, so how many of you prefer it over Mobil 1?
Old Jan 9, 2004 | 11:22 AM
BROOD's Avatar
Default Re: Your thoughts on Royal Purple (tthame1)
It's purple........
Check out http://www.bobistheoilguy.com/ if you seach for info on Royal Purple oil tests you may find some interesting info. These guys know alot about oils
I won't use Royal Purple oils, I stick to RedLine, Mobil1, or Amsoil oils mainly because I have no reasons to change. Royal Purple may be right for your needs....maybe not. I don't think there is a simple yes or no answer. When I looked into it (and this was awhile ago) it seemed that some engines got great resutls with RP oils and some did not.
You would almost need to see oil tests to see what is going on.
Old Jan 9, 2004 | 11:28 AM
Boltz's Avatar
Default Re: Your thoughts on Royal Purple (BROOD)
My brother used to use mobil 1 always in his turbo 95 gsr.... We tried switching to royal purple once and there was a ton less oil burn. We were very suprised, and have always used it since. Not saying its for everyone, but ive seen multiple tests of V8 cars picking up 5-10whp from a switch to royal purple... It could have been rigged but I dont care either way... It worked for us at the time and thats all that matters
Old Oct 25, 2004 | 07:59 PM
631 Teggy's Avatar
Default Re: Your thoughts on Royal Purple (Boltz)
No complaints here - i just switched to it since i'm such a baller - runs great starts great - but i can't speak as to gains or anything... Just no complaints.. I did burn a bit less then i did with the mobil 1 synthetic though...
Old Oct 25, 2004 | 08:29 PM
Garcia-Racing's Avatar
That is all I run in my race car. Except for my breakin. Royal purple
Old Oct 25, 2004 | 08:49 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Your thoughts on Royal Purple (TGARCIARACING)
im running it right now , although i normally run redline . its ok , dont really notice a difference in the 2 , but royal purple seems to be a little thinner.
Old Oct 25, 2004 | 10:15 PM
PrettyLude's Avatar
good motor oil, i heard their tranny motor oil line is not so good
2000CivicEK
Jun 12, 2007 03:42 PM
y2kferari
May 2, 2006 11:18 AM
Blazin Civic
Oct 23, 2005 05:18 PM
handa
45
Aug 5, 2003 01:56 PM
CrxSiRyder
Apr 27, 2003 02:53 AM
