whats the difference between the P74 and the P75 ecus??
Old Jan 7, 2004 | 05:21 PM
birz's Avatar
Default what are the differences between the P74 ecu and the P75 ecu??
the topic says it all.. thanks
Modified by birz at 12:11 PM 1/9/2004
Old Jan 9, 2004 | 03:11 AM
birz's Avatar
Default Re: whats the difference between the P74 and the P75 ecus?? (birz)
no answers? I know you guys know!!
tell me please
Old Jan 9, 2004 | 03:55 AM
Joseph Davis's Avatar
P74 is the P06/P28/everything-OBD1-civic-or-integra-except-P75/P72-and-oddball-P07 family of motherboards/code. Motherboards are marked -1720 or -01F0
P75 is the P72 family of hardware/code, marked -1980.
Big whopp-tee-****, the code is all interchangeable, and the ECUs adhere to the same pinouts and sensor network. As long as you don't try to run KS code on an ECU w/o a KS board, or have your VTEC set below your revlimit on an ECU that doesn't have the VTEC circuitry added, it's all the exact same thing.
Old Jan 17, 2004 | 10:55 AM
birz's Avatar
Default Re: whats the difference between the P74 and the P75 ecus?? (J. Davis)
Thanks alot,,, if My current ECU is a P06 (civic DX) that has been chipped close to the B18B1 specs,,, is it OK? I mean for my application (running on SMC+) 8PSI T25 450cc
mr.f20bhatch
Jul 14, 2015 04:39 PM
valentino2k3
Oct 9, 2004 02:47 PM
neumonik
Mar 20, 2002 04:17 AM
4drGSR
Feb 23, 2002 07:40 PM
boost killz
Sep 7, 2001 10:59 AM
