Turbo type R ?
Old Jan 7, 2004 | 04:39 PM
mstyper's Avatar
Default Turbo type R ?
I have a quick question for you all. I am planning on turboing my Type R. I have been reading post after post on this board. I think I have come up with what type of kit I am going to go with. The kit that I am thinking of using is one made by Full Race. I have seen allot of post where people have built there own custom kits, but I was unable to find out all of the details on the kits that they had built. I will also be using Hondata with this kit. My question is to all of you, do you think this kit is appropriate. If not do you have any other suggestions. I will also be keeping all of me internals sock and doing what some people would say doubling up on my head gaskets to lower my compression.
Please do not say, “Do your research.” Due to the fact that is what most people say.
Thanks for all of your help.
Old Jan 7, 2004 | 04:55 PM
94gsr4dr's Avatar
Default Re: Turbo type R ? (mstyper)
if you are so keen on getting a new headgasket i would get a cometic they are around 100 bucks, also don't forget you will need injectors. If tuned properly the car should run fine. FULL-RACE is a top notch kit.
Old Jan 7, 2004 | 05:00 PM
mstyper's Avatar
Default Re: Turbo type R ? (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">if you are so keen on getting a new headgasket i would get a cometic they are around 100 bucks, also don't forget you will need injectors. If tuned properly the car should run fine. FULL-RACE is a top notch kit.</TD></TR></TABLE>
Sorry for leaving out the injectors bit. Thinks on the tip on the headgasket.
Old Jan 7, 2004 | 05:39 PM
PM-Performance's Avatar
if you plan on keeping the bottom end stock. IMO Full Race isnt worth it. you wont really use it to its efficincy. but rock on if you do , its a hot kit.
Old Jan 7, 2004 | 05:42 PM
jaydmcrx's Avatar
There is a turbo type r on full races website that made over 500whp. Full race is whoop ***. The only thing i dont like is that it doesnt come with fuel, but thats easy to get. You cant go wrong with full race. I have seen slightly tuned itr's run in the low to mid 12's all day on slicks. You are on the right path.
Old Jan 7, 2004 | 07:09 PM
thermal's Avatar
Default Re:
I'm on the same route but I have a JDM ITR motor getting ready to turbo instead. Any suggestion on the size of head gasket I should get?
Old Jan 7, 2004 | 07:19 PM
hulkhb's Avatar
Default Re: Re: (thermalfi'd16)
Boosting the itr motor is a blast, you'll love it.
Old Jan 7, 2004 | 08:08 PM
vtec.dc2's Avatar
whats your hp goal? not something you plan to make later on.. your current hp goal.
Old Jan 7, 2004 | 08:13 PM
integra-modder's Avatar
Default Re: Re: (hulkhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb &raquo;</TD></TR><TR><TD CLASS="quote">Boosting the itr motor is a blast, you'll love it.</TD></TR></TABLE>
It can literally be a blast if you have an incompetent tuner...when done right, they are quick cars...
Old Jan 7, 2004 | 09:48 PM
BoostedITR41's Avatar
Default Re: Re: (integra-modder)
inline pro head gasket is the way to go...I have boosted 15psi for 4 months no prob on a 84k mile bottom end they drop compression a full point.
Old Jan 7, 2004 | 11:29 PM
97ITR60's Avatar
Default Re: Re: (BoostedITR41)
i have the full-race kt and an itr, and i will tell you that it is worth itl. don't listen to anyone else.
Old Jan 8, 2004 | 02:59 AM
MiraiZ's Avatar
Default Re: Re: (97ITR60)
stock bottom save yourself the pain !! do it right the first time and go forged
Old Jan 8, 2004 | 03:20 AM
D3LSLO's Avatar
Default Re: Re: (MiraiZ)
dont double the gasket, ur just gunna raise the chances of blowing it, like everyone else said use one of the listed gaskets, id say inlines since it will do the job your trying to get by doubling.
Old Jan 8, 2004 | 09:29 AM
thermal's Avatar
What sixe inline pro gasket? Where can I get it? I tried their website and I cant seem to find it there...
Old Jan 8, 2004 | 09:35 AM
Default Re: (thermalfi'd16)
save the money and just get the .43 Cometic gasket, it wont drop as much , but still drops it quite a bit and off the top of my head direct from Cometic is only $100 compared to $299 for the inline pro.
Old Jan 9, 2004 | 09:55 AM
c jackson's Avatar
threes
Default Re: (itr206)
if you have any questions on the full-race kits, you can call (480) 830-1522 or 866 fullrace or pm me with questions regarding the kits.
Old Jan 9, 2004 | 10:35 AM
.RAven's Avatar
Dude.. I've always pondered this question also and deamed that it is not worth it. Pull the C5 block and buy a 1st gen B16 longblock from password for 499 and boost that thing. keep it at like 12-13 psi and if it blows like ringlands or the rod goes... thier will be minimal down time because you would just swap that expensive longblock back in and drive that until you get you 500 B16 block rebuilt.
IMHO that's what I would do if I were you.
Old Jan 9, 2004 | 10:51 AM
Type-ARR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermalfi'd16 &raquo;</TD></TR><TR><TD CLASS="quote">I'm on the same route but I have a JDM ITR motor getting ready to turbo instead. Any suggestion on the size of head gasket I should get?</TD></TR></TABLE>
3MM gasket, like inline pro, should lower your CR one full point...
Old Jan 9, 2004 | 10:54 AM
Type-ARR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermalfi'd16 &raquo;</TD></TR><TR><TD CLASS="quote">What sixe inline pro gasket? Where can I get it? I tried their website and I cant seem to find it there...</TD></TR></TABLE>
Call them talk to Stan...
Old Jan 9, 2004 | 02:47 PM
thermal's Avatar
well, I'm sure with proper tuning and management, I'll be able to turbo a typeR. I dont see many TypeR's around my area that are turboed. I'm willing to be different..... safely of course.
Old Jan 11, 2004 | 08:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermalfi'd16 &raquo;</TD></TR><TR><TD CLASS="quote">well, I'm sure with proper tuning and management, I'll be able to turbo a typeR. I dont see many TypeR's around my area that are turboed. I'm willing to be different..... safely of course. </TD></TR></TABLE>
inline pro is just in NOVA you should just go pick one up and screw the shipping
Old Jan 11, 2004 | 08:23 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (BoostedITR41)
just go ahead and throw in some low compression forged pistons.it won't cost much more than the $300 gasket and you can do it while the head is off.
Old Jan 11, 2004 | 08:58 PM
MiraiZ's Avatar
Default Re: (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">just go ahead and throw in some low compression forged pistons.it won't cost much more than the $300 gasket and you can do it while the head is off. </TD></TR></TABLE>
take the word of people who already have the setup...stock pistons/rods will be weakpoint...go forged!
Old Jan 12, 2004 | 12:59 AM
allablur's Avatar
Default Re: (MiraiZ)
if u wanna save some $$$ ditch the itr bloc and sell the swap to some all motor guys pick up a gsr or ls way cheaper use the extra money to have it built meaning sleeves and head work just my opinion i seen way to many people blowing itr motors just for the sake of having a turbo itr... save the motor some one will surely love to nurture it then find a gsr bottom on here that need machining ( save more money) and a ls tranny i think u could get a block and tranny for 2k at most (if its a gsr/ls that needs some love) then u got about 2k-3k from selling your motor to put into building and engine management...thats what im doing wasted all kind of money on an itr(for the sake of having it) and decided to sell it and that is funding most of my ls build
hope this helps
rsx girl
22
Apr 28, 2010 04:08 PM
hurleyrob
May 31, 2006 08:29 AM
DC5AM
Apr 5, 2005 11:46 PM
Naka_Yama
Apr 8, 2003 04:30 PM
ITR #1202
Apr 27, 2002 01:01 PM
