Endyn rollerwave piston dome volume
Old Jan 10, 2004 | 11:05 AM
Seraph0's Avatar
Default Endyn rollerwave piston dome volume
Does anyone know the piston dome displacement for the Endyn rollerwave piston? 84.5mm bore-size.
I'm hoping it's like -3.x cubic cm....
Old Jan 10, 2004 | 01:08 PM
Boostfed's Avatar
New User
Default Re: Endyn rollerwave piston dome volume (MarkC)
Which piston? What is the PROPOSED compression ration and set up? I can calculate it.
Old Jan 10, 2004 | 05:06 PM
Seraph0's Avatar
Default Re: Endyn rollerwave piston dome volume (Boostfed)
Well it's the Wiseco/Endyn "forced-induction" piston with 84.5mm bore. They only make one compression ratio for forced induction if I'm not mistaken. And the CR is given as a range because it depends on so many factors. About the only thing I can tell you about the piston is it has a 1.180" compression height and I don't even really know what that means.
I know how to calculate the CR if I just have the piston dome displacement. I measured my combustion chamber volume already (it was worked on).
Old Jan 10, 2004 | 05:40 PM
Bnjmn's Avatar
-8.3 cc, if I recall correctly. You can verify this by doing at a search at http://www.theoldone.com, in the Ask TOO forum.
Sonny's Avatar
The one for the D series engine is -6.25cc's. I measured it to be around -6 cc's using a super ghetto technique...I was pretty close!
This is the piston that I have:
sonny
DC4_MADMAN
10
Aug 23, 2006 08:52 AM
2 0 3
May 6, 2006 04:23 PM
vinuneuro
Jul 30, 2005 10:51 PM
high_revs
Jun 17, 2005 09:40 AM
shamoo
Jan 29, 2002 05:50 PM
