problem after nitrous install (VCN-2000)
Old Jan 10, 2004 | 09:55 PM
Dancing is Forbidden's Avatar
Default problem after nitrous install (VCN-2000)
My friend Chad up at RandD had the kit on his car for a couple of days and it would throw a TPS code when it was spraying. He took it off cause he got pissed off at it. So I installed it in my car today. Went out to test it out and again with the tps code. It displays TPS ERROR on the display and I get a CEL 7 and the engine jerks kinda bad when the cel comes on. Anyone know what the problem could be? Its a Venom VCN-2000 kit. Thanks for the help.
Modified by EF9_SiR at 4:42 AM 1/11/2004
Old Jan 11, 2004 | 12:01 AM
vtekthis's Avatar
need more info, wet kit or dry, in the actual intk mani or just in the charge pipe?
Old Jan 11, 2004 | 12:07 AM
Default Re: (vtekthis)
ok i guess you dont know this system so you wont be able to help anyways.
Old Jan 11, 2004 | 12:35 AM
pearlcfcivic97's Avatar
how are you going to ask for help if your not willing to give information that will help solve your problem?
Old Jan 11, 2004 | 12:42 AM
Default Re: (awdturbolaser03)
JESUS F-IN CHRIST. It is the VENOM VCN-2000 kit. IT IS A DAMN DRY KIT. IT GOES INTO THE INTAKE. If you don't know what kind of system this is then you wont be able to help. PERIOD!
Old Jan 11, 2004 | 01:45 AM
paulzy's Avatar
I'm pretty sure the signal comes from teh TPS. So check your wire connections.
CHeck the voltage coming form the TPS...
Old Jan 11, 2004 | 12:36 PM
Default Re: problem after nitrous install (EF9_SiR)
bump
Old Jan 11, 2004 | 12:56 PM
PHiZ's Avatar
wow, what a shitty attitude.
-PHiZ
Old Jan 11, 2004 | 12:59 PM
genop's Avatar
Default Re: problem after nitrous install (PHiZ)
no ****, I can see why no one wants to help this ******.
Old Jan 11, 2004 | 01:00 PM
vtekthis's Avatar
wow nice attitude! where on the intake chr pipe is the jet installed? is it before or after the air intake temp sensor? if youre spraying n20 before the sensor, its causing the temp to drasitically decrease.
Old Jan 11, 2004 | 01:05 PM
the reason I am acting the way I am is because if you don't know the system you wont be able to help. This kit IS NOT your typical nitrous kit.
It is installed in the intake arm. I have a 92 so the temp sensor is in the intake mani.
Old Jan 11, 2004 | 01:12 PM
genop's Avatar
Default Re: (EF9_SiR)
did you try venoms website? http://www.venom-performance.c...2.pdf this might help. Please dont yell at me if it doesnt
Old Jan 11, 2004 | 01:45 PM
Default Re: (genop)
I looked there. It did it on my car as well as Chad's. Thats the problem. It is getting a good read because it says what the throttle % is on the display.
Old Jan 11, 2004 | 01:46 PM
genop's Avatar
well if it is happening on both cars wouldnt you have to assume that the problem lies within the unit itself??
Old Jan 11, 2004 | 02:47 PM
johnsona's Avatar
Yeah that is a bad unit i had the same kit and i had other problems with mine not just the error that you got. i had my installed by a shop too. The swaped out the unit and it worked fine. i had them rip that **** out and went with zex now thats a fine *** kit.
Sep 10, 2014 11:16 AM
4door93civic
Jun 6, 2006 04:31 PM
LudaChris
Apr 29, 2006 10:09 PM
punk749
Nov 19, 2001 07:40 AM
