84mm B18c1 with pt67, what flywheel?
I did some searching and I think I want to go with a stock gsr flywheel, but my problem is can I go with an aftermarket "stock" flywheel or should I go with genuine honda flywheel? Or maybe I should go with something completely different? This will be going in a DRAG RACING vehicle btw. Also, where is the best place to get any of the above?
What do you guys think?
Thanks in advance
Thanks in advance
Re: 84mm B18c1 with pt67, what flywheel? (Redlineracer)
Well if you want it for drag racing then you should go with a SFI approved flywheel. The ACT flywheel is nice. Solid billiet iron, no alum. Get the street lite version though it has a little more weight which helps for turbo cars from what I understand.
VtecInteg95
12-11-2003 03:04 PM
