Look, an easily obtained PCB switch for J1 (ECU chipping)
Well I chipped my ECU but wanted a switch in J1 so I could go back to the stock program without having to cut wires and resolder them every time.
My motor is still stock so I can do that.
I found this PCB switch at Radio Shack and it almost fits the little holes.
Radio Shack Part# 275-645A
SPST Submini
PC Board Toggle Switch
In pic 1 you see the switch with one of the legs bent. Thats because I had to bend the leg to get it to go in the other hole on the ECU. This was step 1 in the leg bending.
In pic 2 you see the leg being bent back a little like a hook so it will go in the hole. I opened the switch up to see if I could just remove the middle pin and move it to an empty slot on the switch. I couldnt though because of how the switch actually operates inside, if I moved it when switch it wouldnt make contact.
In pic 3 you see how I mounted it in the ECU. Its at an angle because I wanted to get a little bit more of the bent leg sticking out the otherside of the PCB hole so I could get a good solder spot.
I just tested it and it works fine.
Only bad part is that I wanted "On" to face the other way. Oh well, I can live with that.
SPST Submini
Re: Look, an easily obtained PCB switch for J1 (T-RO)
PHiZ thought of the same thing a while back, insted of that though, he used a small plunger switch. Small and looks really clean.
Rob
Rob
Re: Look, an easily obtained PCB switch for J1 (rjardy)
Yeah Ive always just drilled a hole in the side of the ECU and put the switch thru it and run a pair of wires from the pcb to the switch. That way you can access it from outside the ecu easily.
Man you people have it rough in CA. I couldnt live there with all the crap they put you through for your cars.
1 more reason I love FL.
Re: Look, an easily obtained PCB switch for J1 (cinq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cinq »</TD></TR><TR><TD CLASS="quote">with your ZIF being so big...you have clearance for the other chip?
Do you mean clearance on top when I put in the Eeprom? Yes it fits just fine.
I've also got enough clearance with the ZIF arm, it doesnt touch any of the other chips on the board.
I REALLY like the ZIF sockets I got.
Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">Man you people have it rough in CA. I couldnt live there with all the crap they put you through for your cars.
1 more reason I love FL. </TD></TR></TABLE>
amen to that hehehe
amen to that hehehe
Location: hittin corners so hard you can taste my rims..
Re: (M.A.R.C.)
back from the dead..
thats awsome.. im going to get that switch today, and bust this.. i have smog due so im going to smog it tomorrow or monday, and then proceed to tune boost.
I would think it would work with any setup that has a wire "jumping" J1. The switch basically lets you jump the wire or NOT jump the wire.
SR20 Inside
01-25-2006 09:24 PM
