gasket question???
Old Jan 8, 2004 | 07:48 AM
gdrum's Avatar
Default gasket question???
Okay so I'm putn turbo kit on my h22a4. Lovefab shorty t3/04e.....and all the gaskets for bov, manifold-turbo, downpipe that stuff i dont have. I got a sheet of gasket paper and started making my own...which seem like they would work. Then i found a website that has all of them but they are metal gaskets...wouldl this make a diff or will my paper ones work? help me please thanks
Old Jan 8, 2004 | 07:51 AM
yellowturbo's Avatar
look at http://www.atpturbo.com they have all you need ... with less problem loll
go in shop online ... you will easily find what you need !
Old Jan 8, 2004 | 08:06 AM
green_GSR's Avatar
Default Re: gasket question??? (gdrum)
Metal gaskets are better than paper almost in all cases. You can also apply some gasket maker before you squish the gasket for better sealing too.
Old Jan 8, 2004 | 08:11 AM
gdrum's Avatar
Default Re: gasket question??? (green_GSR)
yeah but a 3 dollar sheet ot make 10 gaskets is cheaper....i know the metal ones are great but im just curious? Will this work fine? Will i leak....with gasket paper...or is it okay?
Old Jan 8, 2004 | 11:48 AM
gdrum's Avatar
anyone?
Old Jan 8, 2004 | 01:56 PM
Bailhatch's Avatar
The gasket paper won't last long at all. You should just get the high temp gasket sheet which has metal on both sides. I think I paid $18 for a 12" X 24" sheet... WAYYY better for what your doing. A thin copper sheet is even better if you want to make your own. Both are very inexpensive and labor intensive (compared to buying gaskets).
oh and if you find some copper sheet stock you will want to anneal it so it will soften and conform to the surfaces better. Just heat it with a torch for a little while.
Old Jan 9, 2004 | 10:40 AM
gdrum's Avatar
Default Re: gasket question??? (Bailhatch)
thanx for the info il be doing that
hondur
Jan 6, 2016 05:57 AM
Chris404
Apr 20, 2013 11:35 PM
Soon2bH2b
Mar 7, 2008 04:09 PM
josh0407
Aug 22, 2007 05:25 AM
95LssTeg
May 18, 2006 06:26 PM
