What would a nice setup consist of?
Old Jan 10, 2004 | 08:11 PM
Sprockett's Avatar
Default What would a nice setup consist of?
Right now, all that's done to my car is basically an intake and exhaust, flywheel and clutch. I want to do some appearance things first, but then I want to focus on the engine. I want to do an FI setup, but am only familiar with RX7 products, since that's where my focus has been the last two years. So, PLEASE, could someone spell out what I would need? Looking for a goal of 250HP. I don't really want to change the internals, but I will if I have to.
- What is a good turbo kit that would help me achieve or exceed my goal?
- What other things (not included in the kit) would I need to look into, and what are some good brands/products?
- I am guessing fuel and ECU are going to be two things - what should I look for?
- anything else I might need
Thanks!
Tyler
Old Jan 10, 2004 | 08:13 PM
streetlvlhatch's Avatar
Default Re: What would a nice setup consist of? (Sprockett)
https://honda-tech.com/zerosearch
you will get good info by searching. Your question is to broad.
Old Jan 10, 2004 | 08:51 PM
Sprockett's Avatar
OK, how about the FMAX kit for the 94+ Integra GSR...is that kit any good? What else would I need to install and get it running the way it should? Would that turbo (t3/4) give me close to 250hp?
Or would a supercharger kit be easier to install and be better for what I am looking for?
I really don't need to get over 250hp, so I shouldn't have to worry about the internals, should I?
Old Jan 10, 2004 | 08:52 PM
DaveF's Avatar
Default Re: (Sprockett)
the kit you speak of is fine for what you would like to do.
Old Jan 10, 2004 | 08:54 PM
Sprockett's Avatar
Default Re: (2.2Lcivic)
Thanks!
So, I am still wondering about the other things I'd need...I didn't see in the kit anything about an ECU upgrade or anything - I would assume I'd need something like that. Then I would assume that would need to be tuned by someone...am I correct, or does that kit come with EVERYTHING I would need?
Old Jan 10, 2004 | 09:05 PM
igotyofire's Avatar
tunning is a great idea no matter what the power level is i belive so start searchin, as for what to use for search id do a search on hondata, or cheaper is the VAFC, ACVR piggy bak ecus, or what u should do best go talk to a local tuner on what he recommends
DC-2uned
May 6, 2007 07:29 PM
1fastvtec
Honda S2000
Dec 13, 2004 09:27 AM
C M S
Nov 27, 2004 06:30 AM
Toretto
Feb 25, 2002 08:20 PM
Immortal23
Nov 21, 2001 10:54 PM
