Engine Build-Ups - What Engine Components can be removed?
Old Jan 9, 2004 | 04:33 AM
Revi's Avatar
Default Engine Build-Ups - What Engine Components can be removed?
What engine components can be removed or have been removed from your engine to go with your turbo/SC set-up? I’m planning on getting rid of all unnecessary things from my engine in my build up and would like to know exactly everything that can go, and what needs to stay. Lets say that the car is a weekend driver and less of a daily driver. Also, explain the reason or advantage of why the component can be removed. Also, lets try to add actual engine components and not just accessories that such as the balancer shafts on an H22. Keep in mind that the stock ECU is no longer in play and has been replaced by AEM EMS / Hondata. And when we say for example “xxx is removed” we mean the entire component , such as hoses, reservoirs, wires ect.
Ill start with the basics:
1. Power Steering – less stress on engine rotation, opens up space in engine compartment.
2. A/C – less stress on engine, opens up space for intercooler routing and turbo, turbo manifold or downpipe.
3. Heater – opens up space.
Anyone else want to add?
Old Jan 9, 2004 | 05:42 AM
Revi's Avatar
Default Re: Engine Build-Ups - What Engine Components can be removed? (Revi-Ra)
Old Jan 9, 2004 | 11:38 PM
Turbo-Honda's Avatar
Lighting up the flywheel..those help wheel rotation..Rev high on RPM ..
Old Jan 9, 2004 | 11:54 PM
JM Performance's Avatar
Default Re: (Turbo-Honda)
cruise control, abs, windshild wiper fluid container, batter (move to trunk or get smaller) fuse box (move), wiring (hide)
Old Jan 9, 2004 | 11:56 PM
99blackcivicSi's Avatar
a/c
power steering
PCV syste
cruise
how is a heater going to open up space? i could have sworn the heater core is under the dash. Keep the heat if it is a street car.
What about all the **** from teh inside.
carpet you don't need
tar
rear seats
rear plastics
spare
jack
bumper supports
floor braces
just start taking **** out that isn't nessecary on a "street" car.
Old Jan 9, 2004 | 11:57 PM
a/c
power steering
PCV syste
cruise
tar
rear seats
rear plastics
spare
jack
bumper supports
floor braces
I will post a pic this weekend of where my "street car" stands as of the this weekend to show you what to take out.
Old Jan 10, 2004 | 12:08 AM
Joseph Davis's Avatar
Default Re: Engine Build-Ups - What Engine Components can be removed? (99blackcivicSi)
If you own a Honda, the best thing to remove is the complete engine. Tub the shell, install V8 w/ boost.
Old Jan 10, 2004 | 12:16 AM
Kwuaymaikrup's Avatar
Default Re: Engine Build-Ups - What Engine Components can be removed? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">If you own a Honda, the best thing to remove is the complete engine. Tub the shell, install V8 w/ boost.</TD></TR></TABLE>
Your sig is ****** hillarious!!!
Old Jan 10, 2004 | 09:20 PM
Default Re: Engine Build-Ups - What Engine Components can be removed? (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">Your sig is ****** hillarious!!! </TD></TR></TABLE>
If you can withstand my endless torrent of verbal abuse and profanity without hurt feelings and wadded panties, I'm a barrel of laughs. Or at least that's what I stand in front of the mirror every morning and tell myself.
Accordian47
Aug 13, 2018 04:55 PM
Armstrong57
29
Sep 16, 2007 11:44 AM
