after regulator install
Old Oct 13, 2003 | 11:56 AM
beaterman's Avatar
Default after regulator install
i just tried to drive my car down the street and now it bogs very badly. am i running to lean or too rich. i need help asap. i only went one house away and i almost stalled when i started off. please help me.
Old Oct 13, 2003 | 12:24 PM
INTEGRAMIKE's Avatar
Default Re: after regulator install (beaterman)
Did you install a pressure guage to see what the pressure is when you adjust it? If not you better go buy one.
Old Oct 13, 2003 | 01:22 PM
beaterman's Avatar
Default Re: after regulator install (INTEGRAMIKE)
yeah i did i figured it out. it was all the way lose and i was trying to adjust it the wrong way. its fixed now. thanks though.
Old Oct 14, 2003 | 11:43 AM
beaterman's Avatar
one last thing. i installed a fuel pressure gauge along with the regulator. at idle i am running about 44 psi but when i give it gas i am running about 52 psi. so should i gauge my psi when i am on the throttle or at idle.
Old Oct 14, 2003 | 12:31 PM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote">one last thing. i installed a fuel pressure gauge along with the regulator. at idle i am running about 44 psi but when i give it gas i am running about 52 psi. so should i gauge my psi when i am on the throttle or at idle.</TD></TR></TABLE>
At idle, with the vacuum hose off of the regulator and folded over shut so it doesn't produce a vacuum leak, which can affect the gauge reading.
The 52psi of fuel pressure you're reading is probably at approximately atmospheric pressure...almost 14.7psi absolute (~100kpa). You might or might not have gotten the manifold pressure to or above atmospheric pressure at full throttle.
The fuel pressure with the FPR vacuum-reference hose off and pinched should be the same as the fuel pressure with manifold pressure equal to atmospheric.
Make sense?
Old Oct 14, 2003 | 03:04 PM
beaterman's Avatar
Default Re: after regulator install (IN VTEC)
hell no. i adjusted the regulator and then put the hose on and read the guage. if i fold the hose over the car starts to rev really high.
Old Oct 14, 2003 | 03:08 PM
IN VTEC's Avatar
The idle will bump a little b/c of the vacuum leak, but it should settle back down.
typeeg
Apr 9, 2012 03:30 PM
JdM_Eg6_SiiR
Jun 13, 2009 02:35 AM
LoseRPunKx182
Sep 15, 2005 09:40 AM
Inextricabledrvr
Aug 11, 2004 03:59 PM
rbf351
Nov 25, 2002 07:46 AM
