hydro lock question
Old Oct 14, 2003 | 05:18 PM
slo2kgsr's Avatar
Default hydro lock question
I have a friend who hydro locked his GS-R. He is sellin the motor cheap. I am just wonderin if you can rebuild a hydro locked motor assuming the block isn't damaged.
Old Oct 14, 2003 | 05:24 PM
skunkintegra's Avatar
Default Re: hydro lock question (tegraLS97)
yep... buy it from him cheap!!
as long as there's no holes in the block, should just need some internals replaced
Old Oct 14, 2003 | 05:50 PM
slo2kgsr's Avatar
Default Re: hydro lock question (skunkintegra)
cool that is what i thought thanks
Old Oct 14, 2003 | 06:50 PM
VTECorona's Avatar
If the block or head warps from the rapid heat change you will need to have it resurfaced which will raise your compression a little, that can be fixed with additional head gasket(s). Besides that, new internals and a complete rebuild and you should be in good shape.
Old Oct 14, 2003 | 06:55 PM
P1mpSlap's Avatar
most likely you'll have to replace the rods and pistons. Then have the crank inspected.
I'd take advantage of it if I were you.
Old Oct 14, 2003 | 07:48 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (P1mpSlap)
Check for holes in the block...my EX motor had several holes when I hydrolocked.
When will people learn???
Old Oct 14, 2003 | 08:21 PM
97hb's Avatar
Hydro locked my motor over a year ago. Still runs great. Many people underestimate how much a honda block can actually take .
Old Oct 14, 2003 | 08:22 PM
VTECorona's Avatar
Default Re: hydro lock question (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">Hydro locked my motor over a year ago. Still runs great. Many people underestimate how much a honda block can actually take .</TD></TR></TABLE>
Me too, mine didnt lock up but just sucked up water. Changed oil (about 20oz of water was in oil when I changed it), plugs, and compression tested and still hitting vtec daily.
bapecivic
Sep 13, 2013 09:13 AM
juergen33911
May 8, 2008 05:02 PM
92EG8
12
Apr 30, 2008 04:30 PM
UncivilB18C
Jan 30, 2008 01:36 PM
555R
May 29, 2001 07:25 AM
