compression ratio question
Old Oct 13, 2003 | 07:17 PM
shibby's Avatar
Default compression ratio question
well im planning on my second car being an integra, ls or rs most likely. i'd like to go with an all motor set up, because i just wont be able to put out 3 grand at 1 time for a turbo, so i wanna build the motor up slowly, piece my piece. the first thing i want to do is raise the compression. if i remember right, the b18b has a 9.1:1 compression ratio, if i raised that to 11.1:1, about how much power would i gain, and would i still be able to run pump gas (92 octane). whats the highest compression ratio i could go up to and still be able to use pump gas? btw im sure someone will tell me to search, since i see that in about every thread, but i did search and didnt find anything. thanx
Old Oct 13, 2003 | 09:35 PM
Slain's Avatar
i'm sure you can run 11.1:1 on 92 pump gas. Many people are running higher compression set ups and are using pump gas. its all in the tuning.
Old Oct 13, 2003 | 09:42 PM
IMPATIENT's Avatar
Default Re: (Slain)
youd be fine running 11:1, my buddy runs 13:1 on pump gas and hes fine, had to put a little bit of fuel in and take some timing out but its fine, an all motor high compression ls motor or are you planning on having a vtec motor swap, i would suggest getting ahold of a vtec head or motor cause vtec feeds off of high compression and you will get alot better results than with your non vtec setup, but i like the idea of a 200 hp all motor ls, but that would be a tough one to achieve for a street car but it would be hot business if you did........good luck dude.....
Old Oct 14, 2003 | 05:53 PM
shibby's Avatar
Default Re: (IMPATIENT)
well i'd like to go for ls vtec but incase you cant tell, i dont know the most about engines and ****. if i went for lsvtec i'd probably be looking to buy a new motor in a month. i havent really thought about getting a gsr motor, but i'd rather just turbo the ls instead of swapping in a gsr. i guess i'll stick with an all motor ls set up, until i learn more about ls vtec. thanks for the input.
o btw im still wonderin, about how much of a power difference would i notice if i b
bumped the compression up to about 11.1:1?
Modified by shibby at 10:29 PM 10/14/2003
Old Oct 14, 2003 | 06:58 PM
91tegrals's Avatar
um just off the top off my head i would say at most maybe a 10hp increase wich isnt bad but throw some cams on top of that and you got youreself a rockin motor, but dont plan on having a 200hp all motor ls its just not going to happen, i have never seen a ls go over 175 hp.....
Old Oct 14, 2003 | 07:06 PM
P1mpSlap's Avatar
I dont think the B18B motor is that low of a CR. I think it's more around 9.8:1 or low 10s. 9.1 :1 CR is ******* horrible CR to drive on without boost. That is the magic number if you want to boost your motor, but if you run N/A man I bet single slam civics could walk on you.
On 93 Octane, the theoretical max is 11.5:1 however 12:1 Seems to run fine. Just remember the higher the CR the more you have to retard the timing to compensate knock.
Lets say you are increasing the CR from 9.8:1 to 11.1:1. That is 1.2 points of increase. For every tenth of a point you gain roughly 2whp (give or take some).
Do the math, it's a significant increase in power.
Old Oct 15, 2003 | 05:18 PM
shibby's Avatar
Default Re: compression ratio question (shibby)
i just checked hmotors and they say a usdm b18b has a compression ratio of 9.2:1. so if i increased that to 11.2:1, that would be an increase of 2 points. if i understand you correctly, that would be a 40hp increase? that seems like an awful lot. did i miss somethin?
Old Oct 15, 2003 | 05:44 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shibby &raquo;</TD></TR><TR><TD CLASS="quote">i just checked hmotors and they say a usdm b18b has a compression ratio of 9.2:1. so if i increased that to 11.2:1, that would be an increase of 2 points. if i understand you correctly, that would be a 40hp increase? that seems like an awful lot. did i miss somethin?</TD></TR></TABLE>
40hp increase? no way...more like 4-8 hp increase.
Old Oct 15, 2003 | 05:53 PM
P1mpSlap's Avatar
Default Re: compression ratio question (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">
40hp increase? no way...more like 4-8 hp increase.</TD></TR></TABLE>
you must not know anything about raising the CR in a car. It is a very dramatic affect.
I wouldn't expect 40hp out of it, maybe like 30 at the most. But yes, It will be very very noticable. Slapping CTR pistons in a i/h/e GSR basically adds around 25whp. It's quite more than a 4-8 hp increase
Old Oct 15, 2003 | 05:55 PM
fivespeedintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shibby &raquo;</TD></TR><TR><TD CLASS="quote">i just checked hmotors and they say a usdm b18b has a compression ratio of 9.2:1</TD></TR></TABLE>
correct.
Old Oct 15, 2003 | 06:00 PM
J337_UNIT's Avatar
Default Re: compression ratio question (P1mpSlap)
http://www.rosspistons.com/CR%20Calculator.htm
try that out
Old Oct 15, 2003 | 06:02 PM
631 Teggy's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">its all in the tuning.</TD></TR></TABLE>
Old Oct 15, 2003 | 06:04 PM
P1mpSlap's Avatar
well damn. My 4-8hp seems to be good enough to romp all over Hype Arrs and WRXs (moderatly stock).
Gotta love this useless 12:1 CR.
Old Oct 15, 2003 | 06:11 PM
J337_UNIT's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">well damn. My 4-8hp seems to be good enough to romp all over Hype Arrs and WRXs (moderatly stock).
Gotta love this useless 12:1 CR. </TD></TR></TABLE>
look, dont get me wrong..every motor is different..but i believe he was talking about the b18b motor and raising the compression ratio on that motor doesnt increase power very much...4-8hp may have been a low figure..it may be more like 12-16 ..it is all about tuning and what not. From what ive HEARD , b18c1 and c5 and b16's respond better to raising compression ratios as opposed to the lower revving b18b motors.
benjamenenglish
28
Mar 10, 2010 05:25 AM
Evolsport
Jul 17, 2009 12:44 PM
black0hatch
Jun 6, 2008 06:38 AM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
redteg
Apr 24, 2003 07:39 AM
