spark plug help!
I bought new spark plugs for my teg. they came stock at 45. i need them to be 30-35. could i just hit it with some wood and a hammer. or would that fu*k the spark plug up.
Do none of you own a proper gapping tool? Don't whack on the electrode. That's just stupid. You see that t-shaped claw thingy on the end of an actual spark plug gapper? Grab the base of the electrode with it, and gently pry in or out to get the proper gap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wcsinx »</TD></TR><TR><TD CLASS="quote">Do none of you own a proper gapping tool? Don't whack on the electrode. That's just stupid. You see that t-shaped claw thingy on the end of an actual spark plug gapper? Grab the base of the electrode with it, and gently pry in or out to get the proper gap.</TD></TR></TABLE>
I have a Snap-On tool for opening, but to close it you just press it down with whatever.
Said pressing tool sounds....nice.
so when i put some new ngk plugs into my car i needed to gap them. what is the stock gap for a 99 ls. also what is the stock gap of ngk v-power plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mns »</TD></TR><TR><TD CLASS="quote">Don't gap your plug!
Try this: http://plugs.janmax.com/
Modified by Mns at 6:14 PM 10/14/2003</TD></TR></TABLE>
ngk's came in the box gapped 1.1, my gsr requires 1.3 gap.. gapping tool is 3 bucks at any local auto shop, takes 15 seconds to gap them. gsr and type r DO NEED gapping. check the manual.
so what is the stock gapping for a 99 ls integra. could not gapping the plugs properly lead to poor gas mileage and bad 1/4 mile times?
Make: ACURA
Model: INTEGRA - LS
Year: 1999
Engine: L4 - 1.8 - B18B1
Stock gap 0.044
Suggested NGK: ZFR5FIX-11 http://ngk.com/results_cross.asp?pid=PZFR5F-11
Suggested BRISK: DOR17LGS http://plugs.janmax.com/msearch.aspx
Model: INTEGRA - LS
Year: 1999
Stock gap 0.044
