cannot downshift to 3rd
Old Nov 20, 2003 | 09:05 AM
cletus's Avatar
Default cannot downshift to 3rd
as title says i cannot downshift into 3rd, when car is moving. i can shift up through all gears fine with slight grind in third and fourth at high rpms. downshifting is fine thorugh all other gears but when i try to put it in 3rd while moving it feels like the gate is blocked. same feeling as if i am trying to shift into 3rd without engaging the clutch. when car is stationary i can shift through all the gears fine. i searched and found some info but nothing with exact sypmtoms. all help is appreciated.
paul
Old Nov 20, 2003 | 09:10 AM
rapid_roy's Avatar
Default Re: cannot downshift to 3rd (cletus)
First, check the level of your transmission fluid. If that is fine then your synchros are going.
In the meantime, double-clutch when downshifting and it shoudl work for now. If that doens't work give the gas a tap when you downshift into 3rd, sometimes that works.
Cheers,
Roy
Old Nov 20, 2003 | 09:13 AM
cletus's Avatar
Default Re: cannot downshift to 3rd (rapid_roy)
i filled with gm synchromesh yesterday and bled the clutch. i forgot to mention if i double clutch it still wont go in sometimes if i pump the clutch repeatedly it will go in the gate. i had a suspicion it was a synchro but wanted to check. thanks roy
junk95civ
Apr 28, 2010 05:54 PM
HondaHemi
12
Feb 9, 2006 06:27 PM
lokodog
Dec 25, 2005 09:39 PM
JDMlyfestyle
21
Sep 24, 2004 02:08 PM
dcrbin22
Sep 11, 2004 11:48 PM
