worn piston rings?
Old Nov 21, 2003 | 06:30 AM
aracer69's Avatar
Default worn piston rings?
i just did a leak down test-turns out air is hissing back from the plug holes on cylinder 3 and 4
does that mean my rings are worn?????
Old Nov 21, 2003 | 06:34 AM
SIanara's Avatar
Default Re: worn piston rings? (aracer69)
are you burning oil at all? how many miles are on the motor?
Old Nov 21, 2003 | 06:56 AM
aracer69's Avatar
oil is going down but there is fresh oil leaking from the front of the engine where the head gasket sits-could it just be that my valves where open
oh and around 40 k on motor
Old Nov 21, 2003 | 07:57 AM
aracer69's Avatar
up
Old Nov 21, 2003 | 10:15 AM
ScootinIntegra's Avatar
I believe that if you had worn rings, you'd hear a hissing in the head...like in the oil cap. I could be wrong, though. Have you lost power at all? Burning oil? Sometimes the dipstick will even blow out if you have worn piston rings...at least on boosted apps (i think)
If you hear it near your intake manifold, you have leaking intake valves...in the exhaust, leaking exhaust valves. If you can't really tell where its coming from, it's headgasket, most likely.
Old Nov 21, 2003 | 10:44 AM
aracer69's Avatar
i havent really lost power at all-it's just my car smokes white sometimes-coolant gets low and oil too-but no white from oil and my coolant still looks green-oil leaks out the front of the engine though-looks like head gasket area
i only hear hissing from the spark plug hole not from the oil cap-no bubbles too from the radiator-i really dont know if it is my rings because it only smokes sometimes when i change gear-
Old Nov 21, 2003 | 10:57 AM
SPOOLINVTEC
Guest
Posts: n/a
do a compression test then you will know right away
Old Nov 21, 2003 | 12:33 PM
aracer69's Avatar
Default Re: worn piston rings? (spoolinvtec)
I just did a leak down test which is better than the compression test-i am norrowing my options to whether it is a faulty headgasket or worn rings
Old Nov 21, 2003 | 11:09 PM
it's not really better...just a different kind of test.
FireInTheHead
Nov 4, 2014 04:15 PM
LShatchie
Aug 4, 2005 02:43 PM
tominos
22
Feb 18, 2003 08:55 PM
CivicBoi
May 27, 2002 11:59 AM
