quick cat question
Old Nov 19, 2003 | 11:24 AM
dip-set's Avatar
Default quick cat question
for those of you that have dealt with installing a catback with the cat bolts being rusted to hell ,is there any chance of the cat (rusted portions like the flange) breaking or by having to get the rusted bolts out by bangin them.. can any damage be done to the cat or o2 sensor for that matter...thanks
Old Nov 19, 2003 | 04:06 PM
NCchris's Avatar
Default Re: quick cat question (teg-your-it)
Yes, the ceramic brick inside the cat is somewhat sensitive to shock. IE banging on an adjacent area could cause it to fracture and, worse, break apart. Can't say for sure, but I wouldn't beat on my cat. Have you tried PB Blaster? Someone handy with a cutting torch could cut the bolts off and not harm the flanges.
HTH
chris
Old Nov 19, 2003 | 05:43 PM
tegmech's Avatar
Default Re: quick cat question (NCchris)
angle grinder
Old Nov 19, 2003 | 06:15 PM
SIK IN DA HED's Avatar
New User
wd40
Old Nov 20, 2003 | 03:43 AM
JimBlake's Avatar
Default Re: quick cat question (SIK IN DA HED)
PB Blaster, Liquid Wrench, WD-40
ViseGrips, 6-point sockets
After all the high-temperature, the bolts usually bend & break pretty easily. Otherwise use a sawzall.
Old Nov 20, 2003 | 04:33 AM
dip-set's Avatar
Default Re: quick cat question (JimBlake)
ok i have a fresh can of pb blaster...all new oem nuts and bolts to bolt the cat to catback...the oem bolts in the cat have a weird shaped head (rectangular with rounded edges) and and lil splines that seem to lock the bolts into the cat so the bolt wont turn..correct? how hard is it to get the old rusted ones out of the cat...i know after cutting or whatever its gonna take to get the nuts of but the bolts i know are gonna be a pita to remove from the cat...
Old Nov 20, 2003 | 09:27 AM
96dc2's Avatar
All I had around was some brake cleaner, and it worked for loosening my cat nuts/bolts.
Old Nov 20, 2003 | 09:30 AM
dip-set's Avatar
Default Re: quick cat question (96dc2)
hopefully the pb blaster will do the job...as far as the weird oem bolts used on the cat to b-pipe can someone confirm this for me...
Old Nov 20, 2003 | 10:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">...the oem bolts in the cat have a weird shaped head (rectangular with rounded edges) and and lil splines that seem to lock the bolts into the cat so the bolt wont turn..correct? ...</TD></TR></TABLE>I don't remember mine being like that. Maybe when I changed my B-pipe they were rusted beyond recognition & I used stainless bolts from the hardware store?
Old Nov 20, 2003 | 10:10 AM
dip-set's Avatar
when i called up acura to order them the specified those are the ones i needed...im hoping so now...but with my luck..i know they wont be the right ones or will not work...damn i need a local friend with a teg and a lil experience behind him for things like this to help me...
Old Nov 20, 2003 | 10:24 AM
96dc2's Avatar
The stock bolts on the stock cat are pressed in.
Old Nov 20, 2003 | 10:25 AM
dip-set's Avatar
exactly...how hard are they to remove so i can use the new ones i have...
Old Nov 20, 2003 | 10:43 AM
svw's Avatar
svw
the bolts pressed into the cat are not hard to remove. i had to saw the binded nut off, shoot in some wd-40, and hammer them out. i'm sure there are better ways, but i had to make due. i noticed some loose particles due to the banging, but i'm sure its negligible.
Old Nov 20, 2003 | 10:47 AM
96dc2's Avatar
Default Re: quick cat question (svw)
You can try his method or get a blow torch to heat them up and hammer them out. I took mine to a muffler shop.
dip-set's Avatar
thanks mam...and loose particles of what the cat? or the bolt...long as i can get them out the rest of the install should go with ease...thats my main concern...
Old Nov 21, 2003 | 06:45 AM
dip-set's Avatar
ok tonights the night i will be installing my catback at my friends shop...any last minute tips or things to be aware of as far as the rusted bolts go and what not...thanks everyone..
Old Nov 21, 2003 | 07:44 AM
gsrpwr's Avatar
I have a 93 gsr and if I wouldn't have found that torch in my friend's garage we would have never gotten the bolts off. We just melted both ends off, and punched the remaining of the bolts out.
Old Nov 21, 2003 | 08:04 AM
dip-set's Avatar
Default Re: quick cat question (gsrpwr)
cool thanks...im sure he has one in his shop if it comes down to needing one
t0kyoStatus
Jan 23, 2009 10:41 PM
fw190bvi
Apr 25, 2005 04:09 PM
Cyber ITR
Dec 17, 2003 07:43 PM
JeremyL
Dec 16, 2002 04:41 PM
