grrr bolt!!!!!
Old Feb 10, 2004 | 01:26 AM
integraGSR213's Avatar
New User
Default grrr bolt!!!!!
i am having trouble getting the rear transmission bolt off. There are 3 bolts back there and the one that is the highest of the three i just can't get a wrench around the bolt to get it off. The bolt is being blocked on the left side by another mount (i think) and a black box, not sure what it is. I don't know all the technical terms for all the parts . I was wondering if anyone changed a tranny before and has run into that type of problem any bit of info would be appreciated.
One more question after the last bolt that i need to take off is removed is it easy to separated the tranny from the engine. any tech help or any type of advice please. I need as much advice or help as i can get.
I am new at this...first time taking out a tranny and all of the work has been done myself. It is taking me forever but it is a great experiance.
thanks
Old Feb 10, 2004 | 06:13 AM
Creep's Avatar
Default Re: grrr bolt!!!!! (integraGSR213)
ttt
Old Feb 10, 2004 | 06:22 AM
New User
Default Re: grrr bolt!!!!! (Creep)
help
Old Feb 10, 2004 | 06:56 AM
tilt's Avatar
#22? I managed to get it from underneath. I think i just used a regular 1/2 drive ratchet and regular socket. I was a tight squeeze but I could get 1 click going on the ratchet. I took the rear mount bracket out so i could put in an insert. I didnt even touch that bolt the first time i dropped the tranny, so you might not need to.
Old Feb 10, 2004 | 08:51 AM
ThePro's Avatar
It's been awhile for me, but I think I just took the whole mount off. I couldn't get at it either.
Either than or I did get that bolt off by doing one click on the ratchet for (seriously) an hour and a half. Ugh.
Sorry I couldn't narrow it down more. But I had problems with two of the bolts in the rear of the engine bay when I took out the engine, one of those two solutions is what I did.
Old Feb 10, 2004 | 09:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
don't forget to take the starter off, it has really long bolts that will keep the bellhousing from coming off if you forget to remove it.
Old Feb 10, 2004 | 04:02 PM
New User
Default Re: grrr bolt!!!!! (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">
#22? I managed to get it from underneath. I think i just used a regular 1/2 drive ratchet and regular socket. I was a tight squeeze but I could get 1 click going on the ratchet. I took the rear mount bracket out so i could put in an insert. I didnt even touch that bolt the first time i dropped the tranny, so you might not need to. </TD></TR></TABLE>
i think the bolt that i want to remove to get the tranny off the engine is #32. I have to use a wrench because i cannot get a ratchet over the nut because there is black box and i think another mount blocking it. I do not have enough room to get a good grip on the nut with my wrench. If I am able to get it off does the tranny just slide off the engine easy or do I have to struggle to pull it off. should i have a jack supporting the engine and the tranny? This is what I get for trying this myself.
thanks for the info everyone
Modified by integraGSR213 at 5:15 AM 2/11/2004
groundup.
Honda Civic (2001 - 2005)
Feb 29, 2012 05:34 PM
germanturtle
Nov 13, 2011 07:42 PM
asubennett
Aug 21, 2003 05:14 PM
Blowensi
Jul 9, 2003 08:38 PM
ragejed
Sep 8, 2002 04:33 PM
